Bareos client on master prevents upgrade
Hi@all,
I would test the upgrade to 5.0 on one of the coming weekends.
The Bareos client (20.0.1-4) is installed on the master (4.4.8) which prevents the update.
What is the procedure for the upgrade?
  • Update Bareos client -> UCS Upgarde
  • Uninstall Bareos client -> UCS Upgrade -> Reinstall Bareos client
with best
sven
