Automount doesn’t work like expected
Very strange experience: As I mentioned in another thread I could log in with kerberized ssh and on some servers it mounts my home directory and on servers it doesn’t. I don’t have any clue, what are the differencies between them exept their roles: it works on dc master and dc backup as well as on member servers; on slave servers (with or without samba) it only works sometimes. How to fix this issue? Or what did I do wrong?
I think the problem lies here. Instead of ordinary automount, Univention uses its own way
/usr/sbin/univention-mount-homedir
And this seems not to work on all my servers. Please help to fix it.
Just found the solution or a work around. I copied the files /etc/pam.d/common-* from a working server to the ones, that don’t. And it works. I don’t know what exactly did the trick. Something had changed one or more of the particular files.
