Hallo liebe Community,
ich habe das Problem, dass bei einem UCS Backup Server 4.2-4 errata 418 nicht automatisch, trotz Richtlinie, upgedatet wird - Aktuell wäre das erratalevel 425.
Hier die updater.log des Backupservers. Ich habe eingestellt das die auto errata Update jeden Dienstag um 04:00 installiert werden sollen.
Starting univention-upgrade. Current UCS version is 4.2-4 errata418
Checking for package updates: found
Please rerun command without --check argument to install.
The following packages will be installed:
libconfuse-common,libconfuse0,aglfn,gnuplot-tex,gnuplot-data,keyutils,python-blinker,python-itsdangerous
The following packages will be upgraded:
libwmf0.2-7,univention-base-packages,univention-base-files,bmon,cifs-utils,gnuplot-nox,gnuplot,htop,iperf,libconfig-tiny-perl,libgnomevfs2-common,libtcmalloc-minimal4,python-flask,python-sleekxmpp,python-trml2pdf,univention-appcenter,univention-management-console-module-apps,univention-management-console-module-appcenter,univention-apache,univention-appcenter-docker,python-univention-appcenter,univention-s4-connector,python-univention-connector-s4,tmux,univention-errata-level
Checking for app updates: Calling upgrade-search
2018-07-18 15:11:45,448 DEBUG:univention.appcenter.actions.upgrade-search:Calling upgrade-search
0
2018-07-18 15:11:45,476 DEBUG:univention.appcenter.actions.upgrade-search.progress:0
Calling update
2018-07-18 15:11:45,478 DEBUG:univention.appcenter.actions.update:Calling update
0
2018-07-18 15:11:45,478 DEBUG:univention.appcenter.actions.update.progress:0
Downloading "https://appcenter.software-univention.de/meta-inf/categories.ini"...
2018-07-18 15:11:45,491 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/categories.ini"...
... Not Modified
2018-07-18 15:11:45,643 DEBUG:univention.appcenter.actions.update: ... Not Modified
Downloading "https://appcenter.software-univention.de/meta-inf/rating.ini"...
2018-07-18 15:11:45,646 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/rating.ini"...
... Not Modified
2018-07-18 15:11:45,795 DEBUG:univention.appcenter.actions.update: ... Not Modified
Downloading "https://appcenter.software-univention.de/meta-inf/license_types.ini"...
2018-07-18 15:11:45,798 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/license_types.ini"...
... Not Modified
2018-07-18 15:11:45,944 DEBUG:univention.appcenter.actions.update: ... Not Modified
Downloading "https://appcenter.software-univention.de/meta-inf/ucs.ini"...
2018-07-18 15:11:45,946 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/ucs.ini"...
... Not Modified
2018-07-18 15:11:46,092 DEBUG:univention.appcenter.actions.update: ... Not Modified
Downloading "https://appcenter.software-univention.de/meta-inf/4.2/index.json.gz"...
2018-07-18 15:11:46,113 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/4.2/index.json.gz"...
Downloading "https://appcenter.software-univention.de/meta-inf/4.2/index.json.gz.gpg"...
2018-07-18 15:11:46,334 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/4.2/index.json.gz.gpg"...
Downloading "https://appcenter.software-univention.de/meta-inf/4.2/all.tar.gpg"...
2018-07-18 15:11:46,484 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/4.2/all.tar.gpg"...
Downloading "http://appcenter.software-univention.de/meta-inf/4.2/all.tar.zsync"...
2018-07-18 15:11:46,636 INFO:univention.appcenter.actions.update:Downloading "http://appcenter.software-univention.de/meta-inf/4.2/all.tar.zsync"...
Calling zsync http://appcenter.software-univention.de/meta-inf/4.2/all.tar.zsync -q -o /var/cache/univention-appcenter/appcenter.software-univention.de/4.2/.all.tar
2018-07-18 15:11:46,726 DEBUG:univention.appcenter.actions.update:Calling zsync http://appcenter.software-univention.de/meta-inf/4.2/all.tar.zsync -q -o /var/cache/univention-appcenter/appcenter.software-univention.de/4.2/.all.tar
Extracting archive in /var/cache/univention-appcenter/appcenter.software-univention.de/4.2
2018-07-18 15:11:47,894 DEBUG:univention.appcenter.actions.update:Extracting archive in /var/cache/univention-appcenter/appcenter.software-univention.de/4.2
Removing old files...
2018-07-18 15:11:47,894 DEBUG:univention.appcenter.actions.update:Removing old files...
Unpacking /var/cache/univention-appcenter/appcenter.software-univention.de/4.2/.all.tar...
2018-07-18 15:11:47,951 DEBUG:univention.appcenter.actions.update:Unpacking /var/cache/univention-appcenter/appcenter.software-univention.de/4.2/.all.tar...
Calling tar -C /var/cache/univention-appcenter/appcenter.software-univention.de/4.2 -xf /var/cache/univention-appcenter/appcenter.software-univention.de/4.2/.all.tar
2018-07-18 15:11:48,022 DEBUG:univention.appcenter.actions.update:Calling tar -C /var/cache/univention-appcenter/appcenter.software-univention.de/4.2 -xf /var/cache/univention-appcenter/appcenter.software-univention.de/4.2/.all.tar
Downloading "https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz"...
2018-07-18 15:11:48,240 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz"...
Downloading "https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz.gpg"...
2018-07-18 15:11:48,476 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz.gpg"...
Downloading "https://appcenter.software-univention.de/meta-inf/4.1/all.tar.gpg"...
2018-07-18 15:11:48,619 INFO:univention.appcenter.actions.update:Downloading "https://appcenter.software-univention.de/meta-inf/4.1/all.tar.gpg"...
Downloading "http://appcenter.software-univention.de/meta-inf/4.1/all.tar.zsync"...
2018-07-18 15:11:48,762 INFO:univention.appcenter.actions.update:Downloading "http://appcenter.software-univention.de/meta-inf/4.1/all.tar.zsync"...
Calling zsync http://appcenter.software-univention.de/meta-inf/4.1/all.tar.zsync -q -o /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/.all.tar
2018-07-18 15:11:48,830 DEBUG:univention.appcenter.actions.update:Calling zsync http://appcenter.software-univention.de/meta-inf/4.1/all.tar.zsync -q -o /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/.all.tar
Extracting archive in /var/cache/univention-appcenter/appcenter.software-univention.de/4.1
2018-07-18 15:11:50,393 DEBUG:univention.appcenter.actions.update:Extracting archive in /var/cache/univention-appcenter/appcenter.software-univention.de/4.1
2018-07-18 15:11:50,394 DEBUG:univention.appcenter.actions.update:Removing old files...
Unpacking /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/.all.tar...
2018-07-18 15:11:50,460 DEBUG:univention.appcenter.actions.update:Unpacking /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/.all.tar...
Calling tar -C /var/cache/univention-appcenter/appcenter.software-univention.de/4.1 -xf /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/.all.tar
2018-07-18 15:11:50,526 DEBUG:univention.appcenter.actions.update:Calling tar -C /var/cache/univention-appcenter/appcenter.software-univention.de/4.1 -xf /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/.all.tar
Cache outdated. Need to rebuild
2018-07-18 15:11:50,741 DEBUG:univention.appcenter.cache:Cache outdated. Need to rebuild
Unable to get mtime for cache: [Errno 2] No such file or directory: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.2/.apps.en.json'
2018-07-18 15:11:50,741 DEBUG:univention.appcenter.cache:Unable to get mtime for cache: [Errno 2] No such file or directory: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.2/.apps.en.json'
Cannot load cache: mtimes of cache files do not match: None < 1531919508.2213778
2018-07-18 15:11:50,741 DEBUG:univention.appcenter.cache:Cannot load cache: mtimes of cache files do not match: None < 1531919508.2213778
Saved 189 apps into cache
2018-07-18 15:11:51,868 DEBUG:univention.appcenter.cache:Saved 189 apps into cache
2018-07-18 15:11:51,868 DEBUG:univention.appcenter.cache:Cache outdated. Need to rebuild
Unable to get mtime for cache: [Errno 2] No such file or directory: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.1/.apps.en.json'
2018-07-18 15:11:51,868 DEBUG:univention.appcenter.cache:Unable to get mtime for cache: [Errno 2] No such file or directory: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.1/.apps.en.json'
Cannot load cache: mtimes of cache files do not match: None < 1531919510.7254148
2018-07-18 15:11:51,869 DEBUG:univention.appcenter.cache:Cannot load cache: mtimes of cache files do not match: None < 1531919510.7254148
Saved 380 apps into cache
2018-07-18 15:11:53,877 DEBUG:univention.appcenter.cache:Saved 380 apps into cache
Updating app files...
2018-07-18 15:11:54,721 DEBUG:univention.appcenter.actions.update:Updating app files...
File: /usr/share/univention-management-console/modules/apps.xml
2018-07-18 15:11:54,812 INFO:univention.appcenter.actions.update:File: /usr/share/univention-management-console/modules/apps.xml
Multifile: /etc/apache2/sites-available/000-default.conf
2018-07-18 15:11:57,581 INFO:univention.appcenter.actions.update:Multifile: /etc/apache2/sites-available/000-default.conf
2018-07-18 15:11:57,582 INFO:univention.appcenter.actions.update:
Multifile: /etc/apache2/sites-available/default-ssl.conf
2018-07-18 15:12:00,111 INFO:univention.appcenter.actions.update:Multifile: /etc/apache2/sites-available/default-ssl.conf
2018-07-18 15:12:00,112 INFO:univention.appcenter.actions.update:
File: /usr/share/univention-management-console/i18n/de/apps.mo
2018-07-18 15:12:03,008 INFO:univention.appcenter.actions.update:File: /usr/share/univention-management-console/i18n/de/apps.mo
2018-07-18 15:12:03,009 INFO:univention.appcenter.actions.update:
File: /usr/share/univention-portal/apps.json
2018-07-18 15:12:06,580 INFO:univention.appcenter.actions.update:File: /usr/share/univention-portal/apps.json
Updating app icon files in UMC directory...
2018-07-18 15:12:09,127 DEBUG:univention.appcenter.actions.update:Updating app icon files in UMC directory...
100
2018-07-18 15:12:10,092 DEBUG:univention.appcenter.actions.update.progress:100
Checking dhcp-server=11.0.0
2018-07-18 15:12:10,100 DEBUG:univention.appcenter.actions.upgrade-search:Checking dhcp-server=11.0.0
Checking kopano-core=8.4.5.0
2018-07-18 15:12:10,111 DEBUG:univention.appcenter.actions.upgrade-search:Checking kopano-core=8.4.5.0
Checking kopano-webapp=3.3.0.610
2018-07-18 15:12:10,122 DEBUG:univention.appcenter.actions.upgrade-search:Checking kopano-webapp=3.3.0.610
Checking samba4=4.6
2018-07-18 15:12:10,134 DEBUG:univention.appcenter.actions.upgrade-search:Checking samba4=4.6
Checking z-push-kopano=2.3.7
2018-07-18 15:12:10,147 DEBUG:univention.appcenter.actions.upgrade-search:Checking z-push-kopano=2.3.7
100
2018-07-18 15:12:10,158 DEBUG:univention.appcenter.actions.upgrade-search.progress:100
none
Checking for release updates: found: UCS 4.3-0
Hier Bilder der policies:
Danke für die Hilfe im Voraus!
