Authenticating via MS-RPC from Cisco ISE
We have a third party setting up Cisco ISE for our organization. They complain that they are not able to autenticate users using MS-RPC against UCS, as they are used to do in conventional AD environments.
They worry that the setup will not work as expected when put in production, although Kerberos authentication works fine
In order to put the issue to rest, does anybody know whether it is possible to allow authentication via MS-RPC from Cisco ISE.
Many thanks in advance!
best regards
Harald
