Authenticate external Devices with UCS LDAP
I am trying to authenticate Desktop Management (KACE product) with through UCS.
I can get the app to connect to the ldap with the follwing settings
Hostname: server IP
port: my port
username: CN=Administrator,CN=Users,DC=mydomain,DC=com
password: administratorpassword
I get error message “ERROR:Errno 49 Invalid credentials.”
But when i use this account to login computer, it could run well.
Thanks
Can you connect with ldapsearch?
Have a look at this Cool Solution: https://wiki.univention.de/index.php/Cool_Solution_-_LDAP_search_user
BR,
Jörn
Hi Jorn,
let me know how to issue shell command in UCS ?
Regards,
Isa
Hey,
I seem to remember from back when I still had a KACE system that the input fields in KACE’s LDAP configuration were rather limited regarding the password length (or something like that) — e.g. only 12 or 16 characters. As far as I remember there wasn’t a workaround. What I ended up doing was adding a separate user just for KACE (it’s only about searching the LDAP anyway) whose password length matches what KACE accepted.
Kind regards,
mosu
You can connect to the server via SSH with root account and the password of the Administrator account.
Hi Jolentes,
I am sorry for late respond. i will try to connect to the server via SSH.
thanks for your support.
