I have installed UCS (UCS 5.0-1 errata187) and everything seems to be working except for the appcenter.
When i go from the portal to the appcenter i get a black screen with a red square with the message Error.
When i update via univention-app update i get the following message:
Downloading “https://appcenter.software-univention.de/meta-inf/app-categories.ini”…
Error
Logs are giving the following messages:
appcenter.log
2373 actions.upgrade-search 22-01-17 17:08:25 [ DEBUG]: Calling upgrade-search
2373 actions.upgrade-search.progress 22-01-17 17:08:25 [ DEBUG]: 0
2373 actions.update 22-01-17 17:08:25 [ DEBUG]: Calling update
2373 actions.update.progress 22-01-17 17:08:25 [ DEBUG]: 0
2373 actions.update 22-01-17 17:08:25 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/app-categories.ini”…
2373 actions.update 22-01-17 17:08:25 [CRITICAL]: Error
2373 actions.update.progress 22-01-17 17:08:25 [ DEBUG]: 100
2373 actions.upgrade-search 22-01-17 17:08:25 [CRITICAL]: Error
2373 actions.upgrade-search.progress 22-01-17 17:08:25 [ DEBUG]: 100
2373 cache 22-01-17 17:08:25 [ DEBUG]: Unable to get mtime for archive: [Errno 2] No such file or directory: ‘/var/cache/univention-appcenter/appcenter.software-univention.de/5.0/.all.tar’
2373 cache 22-01-17 17:08:25 [ DEBUG]: Cannot load cache: Getting cached attributes failed
2373 cache 22-01-17 17:08:25 [ DEBUG]: Saved 0 apps into cache
univention-console-module-appcenter.log
17.01.22 16:38:50.041 DEBUG_INIT
17.01.22 16:38:50.256 MODULE ( PROCESS ) : Loading python module.
17.01.22 16:38:50.287 MODULE ( PROCESS ) : Imported python module.
17.01.22 16:38:50.287 MODULE ( PROCESS ) : Module instance created.
17.01.22 16:38:50.287 MODULE ( PROCESS ) : Module socket initialized.
17.01.22 16:38:50.309 MODULE ( PROCESS ) : Setting user LDAP DN ‘uid=Administrator,cn=users,dc=home,dc=lan’
17.01.22 16:38:50.309 MODULE ( PROCESS ) : Setting auth type to None
17.01.22 16:38:50.309 MODULE ( PROCESS ) : Initializing module.
17.01.22 16:38:51.216 MODULE ( ERROR ) : Error returning cached query: [Errno 2] No such file or directory: ‘/var/cache/univention-appcenter/umc-query.json’
17.01.22 16:38:51.323 MODULE ( PROCESS ) : Downloading “https://appcenter.software-univention.de/meta-inf/app-categories.ini”…
17.01.22 16:38:51.391 MODULE ( WARN ) : Error
17.01.22 16:38:51.391 MODULE ( PROCESS ) : Error
17.01.22 16:38:51.394 MODULE ( PROCESS ) : Could not load suggestions.
17.01.22 16:48:52.052 MAIN ( WARN ) : Shutting down all open connections
17.01.22 16:48:52.053 MAIN ( WARN ) : Shutting down all open connections
Can anyone help me to make the appcenter work.
regards.
