Apache not starting any more (was: Apache startet nicht mehr)
After the update to the current version Apache does not start anymore. I get the message when starting manually:
[…] Starting apache2 (via systemctl): apache2.serviceJob for apache2.service failed because the control process exited with error code.
See “systemctl status apache2.service” and “journalctl -xe” for details.
failed!
====Original====
Nach dem Update auf die aktuelle Version startet der Apache nicht mehr. Ich bekomme beim manuellen starten die Meldung:
failed!
So as it is written, what does it tell you?
/CV
Check your template files (univention-check-templates). If it reports some of the Apache templates as modified, you’ll have to merge your manual modifications and the new templates, commit them with ucr commit <name-of-file-to-create> and restart Apache.
