Ansible: How to create a policy with module univention_directory_manager?
I try to create a policy with ansible via:
  - name: Erstelle Policy f. Verwaltungs-Server
    delegate_to: "PRIMARY"
    univention.ucs_modules.univention_directory_manager:
      module: "policies/registry"
      state: "present"
      position: "cn=policies,{{ OUDN }}"
      dn: "cn=ou-default-verw-policy,cn=policies,{{ OUDN }}"
      set_properties:
        - property: "name"
          value: "ou-default-verw-policy"
        - property: "registry"
          value:
            ldap/server/name: "{{ SERVER }}.edu.silk-it.de"
It doesn’t throw an error message, but the policy is not created either.
Worse: when that policy already exists, it throws an error and doesn’t continue the playbook.
  • Is there a switch for “–ignore_exists” as in udm? I presumed “state: present” would automatically take care of it…
  • What’s wrong with the code above, why does it not create that policy?
I’m using UCS: 5.0-7 errata1011 and version 3.1.0 of the univention-ucs_modules
TIA,
Jens-Peter
Hi Jens-Peter,
i tested this with version v3.1.3 and had no issues (created policy, modified policy, skipped updating policy (if not required) and removed policy) .
Would it be an option to upgarde the module?
My test code was:
  hosts: "pdn"
  gather_facts: false
  become: true
  tasks:
    - name: "create policy"
        module: 'policies/registry'
        state: 'present'
        position: 'cn=policies,dc=ucs,dc=test'
        dn: 'cn=Test,cn=policies,dc=ucs,dc=test'
        set_properties:
          - property: 'name'
            value: 'Test'
          - property: 'registry'
            value:
              ldap/server/name: pdn.test.ucs
Best regards,
Tim
actual it is not possible to set boolean values within the module ‘policies/registry’.
Example Code:
  tasks:
          state: 'present'
          position: 'cn=policies,dc=test,dc=de'
          dn: 'cn=Test,cn=policies,dc=test,dc=de'
          set_properties:
            - property: 'name'
              value: 'Test'
              value:
                test/value: true
Errorstring:
fatal: [XXXXXXX]: FAILED! => {"ansible_facts": {"discovered_interpreter_python": "/usr/bin/python3"}, "changed": false, "meta": {"changed_objects": [], "created": {}, "modified": {}, "removed": {}}, "msg": "'bool' object has no attribute 'encode'"}
Have you a workaround or bugfix for this problem
best regards
Michael
Can you specify in which case you want to have a boolean value?
In all cases i know it has to be string syntax inside the UCR setting.
So test/value: "true" would be the correct approach.
UCS normally uses “configRegistry.is_true()” which cares about different types of “true”.
Hi Tim,
this works for me, so everything is fine. The case was, we have an ansible linted variable file, where some Variables was set to True.
best regards
Michael
