Hallo Herr Ahrnke,
vermutlich ja: Zarafa in Version 7.1.11-R1 ist aus dem Appcenter installiert. Ist dort der Webmailer PHP-basiert?
Owncloud und Zarafa haben auf dem Server bislang mehr oder weniger friedlich koexistiert. Bei Updates gab es in der Vergangenheit kleinere Schwierigkeiten bei der Installation, die aber mit Hilfe eines Beitrags dieses Forums umgangen werden konnten.
In /var/lib/owncloud/owncloud.log finden sich nach dem Update u.a.:
{"app":"remote","message":"Connection to LDAP server could not be established","level":4,"time":"2015-09-24T15:27:14+00:00"}
{"app":"PHP","message":"PHP Startup: Unable to load dynamic library '\/usr\/lib\/php5\/20100525\/imap.so' - \/usr\/lib\/php5\/20100525\/imap.so: cannot open shared object file: No such file or directory at Unknown#0","level":3,"time":"2015-09-24T15:27:46+00:00"}
{"app":"user_ldap","message":"No LDAP Connection to server server1.xxx.de","level":3,"time":"2015-09-24T15:27:46+00:00"}
{"app":"hook","message":"error while running hook (\\OC\\Files\\Storage\\Shared::setup): Connection to LDAP server could not be established","level":3,"time":"2015-09-24T15:27:46+00:00"}
und
{"app":"remote","message":"Connection to LDAP server could not be established","level":4,"time":"2015-09-24T15:28:50+00:00"}
{"app":"user_ldap","message":"Bind failed: 49: Invalid credentials","level":3,"time":"2015-09-24T15:29:22+00:00"}
{"app":"user_ldap","message":"No LDAP Connection to server server1.xxx.de","level":3,"time":"2015-09-24T15:29:22+00:00"}
{"app":"hook","message":"error while running hook (\\OC\\Files\\Storage\\Shared::setup): Connection to LDAP server could not be established","level":3,"time":"2015-09-24T15:29:22+00:00"}
aber auch vor dem Update bereits in großer Anzahl:
{"app":"user_ldap","message":"Connection could not be established","level":3,"time":"2015-09-21T17:56:27+00:00"}
{"app":"PHP","message":"PHP Startup: Unable to load dynamic library '\/usr\/lib\/php5\/20100525\/imap.so' - \/usr\/lib\/php5\/20100525\/imap.so: cannot open shared object file: No such file or directory at Unknown#0","level":3,"time":"2015-09-21T18:01:01+00:00"}
{"app":"user_ldap","message":"Bind failed: 49: Invalid credentials","level":3,"time":"2015-09-21T18:06:31+00:00"}
Trotz der Fehlermeldungen hat der Zugriff auf Owncloud von mehreren Geräten im Netzwerk sowie mobil von aussen lange Zeit gut funktioniert.
Gruß
Uwe
