im scalix-res.log sind ansonsten keine Fehler zu finden, aber im scalix-caa.log ist ein FATAL
[quote]2010-04-20 17:36:38,102 DEBUG [SOAPDispatcherServlet.onMessage:159] **** Start o
f Message Handling ****
2010-04-20 17:36:38,103 DEBUG [SOAPHelper.getElementValue:144] Found ServiceType
2010-04-20 17:36:38,103 DEBUG [CAAConfigLoader.getValue:56] Looking for config f
or scalix.res, key disabled found null
2010-04-20 17:36:38,104 DEBUG [SOAPHelperUtils.getSoapBodyElement:179] Body elem
ent1 CAARequestMessage = null
2010-04-20 17:36:38,104 DEBUG [SOAPHelperUtils.getSoapBodyElement:187] Body elem
ent2 ServiceType = scalix.res
ent2 Credentials = null
2010-04-20 17:36:38,104 DEBUG [SOAPHelperUtils.getSoapBodyElement:190] Found Cre
dentials
2010-04-20 17:36:38,105 DEBUG [SOAPHelperUtils.getCredentials:255] local name=id
2010-04-20 17:36:38,105 DEBUG [SOAPHelperUtils.getCredentials:256] qualified nam
e=id
2010-04-20 17:36:38,105 DEBUG [SOAPHelperUtils.getCredentials:272] local name=na
me
2010-04-20 17:36:38,105 DEBUG [SOAPHelperUtils.getCredentials:273] qualified nam
e=name
2010-04-20 17:36:38,105 DEBUG [SOAPHelperUtils.getCredentials:277] value=Adminis
trator
2010-04-20 17:36:38,106 DEBUG [SOAPHelperUtils.getCredentials:272] local name=pa
sswd
2010-04-20 17:36:38,106 DEBUG [SOAPHelperUtils.getCredentials:273] qualified nam
e=passwd
2010-04-20 17:36:38,106 DEBUG [SOAPHelperUtils.getCredentials:282] value=xxxxxxx
xx
2010-04-20 17:36:38,106 DEBUG [SOAPHelperUtils.getSOAPBodyElementValue:69] Body
element1 CAARequestMessage = null
[/quote]
[quote]2010-04-20 17:36:38,113 DEBUG [RESService.authenticateAndAuthorizeUser:218] AUTH
previously authenticated as Administrator?
2010-04-20 17:36:38,113 DEBUG [RESService.authenticateAndAuthorizeUser:241] AUTH
yes, pre-authenticated…
2010-04-20 17:36:38,114 DEBUG [RESService.authenticateAndAuthorizeUser:274] AUTH
previously authorized?
2010-04-20 17:36:38,114 DEBUG [RESService.authenticateAndAuthorizeUser:295] AUTH
*[/quote]
[quote]2010-04-20 17:36:38,116 DEBUG [RESService.authenticateAndAuthorizeUser:384] AUTH
done
2010-04-20 17:36:38,117 DEBUG [CAAConfigLoader.getValue:56] Looking for config f
or scalix.res, key connection.mode found 1
2010-04-20 17:36:38,117 DEBUG [CAAConnectionManager.getConnection:71] Connection
mode is 1
or scalix.res, key connection.configurator.class found com.scalix.caa.framework.
CAAConnectionPoolManager
2010-04-20 17:36:38,118 DEBUG [CAAConnectionPoolManager.logConnectionPool:325] C
onnection pool scalix.res status: min=2,max=10,size=2,used=0
2010-04-20 17:36:38,118 DEBUG [CAAConnectionPoolManager.getFreeConnectionFromPoo
l:129] Looking at connection 0
l:146] Found a free connection (0) for scalix.res and endpoint ucs1.bergl
and-gruppe.de:80/res/RESDispatcher
l:199] Retrieved connection from pool for scalix.res and endpoint ucs1.be
rgland-gruppe.de:80/res/RESDispatcher
2010-04-20 17:36:38,119 DEBUG [CAAConnectionPoolManager.logConnectionPool:325] C
onnection pool scalix.res status: min=2,max=10,size=2,used=1
2010-04-20 17:36:38,120 FATAL [RESServiceHandler.GetMailNodesList:1004] java.lan
g.NumberFormatException: For input string: "6 ":ucs1.bergland-gruppe.de
java.lang.NumberFormatException: For input string: "6 "
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at com.scalix.sac.ubermgr.res.RESServiceHandler.GetMailNodesList(RESServ
iceHandler.java:970)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.scalix.sac.ubermgr.caa.RESService.doRequest(RESService.java:134)
at com.scalix.caa.soap.SOAPDispatcherServlet.onMessage(SOAPDispatcherSer
vlet.java:268)
at com.scalix.caa.soap.SAAJServlet.doPost(SAAJServlet.java:123)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl
icationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF
ilterChain.java:188)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperV
alve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextV
alve.java:172)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.j
ava:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.j
ava:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineVal
ve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.jav
a:174)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:775)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.ja
va:704)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSock
et.java:897)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadP
ool.java:689)
at java.lang.Thread.run(Unknown Source)
2010-04-20 17:36:38,120 DEBUG [CAAConnectionPoolManager.freeConnection:88] Freei
ng a connection
2010-04-20 17:36:38,120 DEBUG [CAAConnectionPoolManager.logConnectionPool:325] C
2010-04-20 17:36:38,121 ERROR [GetMailNodesList.buildResponseMessage:107] Skippi
ng server ucs1.bergland-gruppe.de. No document received!
2010-04-20 17:36:38,122 DEBUG [SAAJServlet.doPost:130] ************ Request End
Success ***************
[/quote]
