Univention distributes container images (for example UCS App Center apps such
as Keycloak, and Nubus components) from the registry
artifacts.software-univention.de. When a client downloads an image layer, the
registry answers with an HTTP 307 redirect to its object-storage backend
s3.de-west-1.psmanaged.com.
If your firewall or HTTP proxy only allows artifacts.software-univention.de,
the image manifest can be read but the actual layers fail to download, so the
pull or app installation/upgrade fails.
You must allow both hosts:
| Host | Purpose | Protocol / Port |
artifacts.software-univention.de |
Registry API, authentication token, manifests | HTTPS / 443 |
s3.de-west-1.psmanaged.com |
Object storage (image layers / blobs), served via 307 redirect | HTTPS / 443 |
Background
artifacts.software-univention.de is a Harbor registry. For efficiency, Harbor
does not stream large image blobs itself; it issues a short-lived, pre-signed
redirect to the S3-compatible object storage where the data actually lives.
That storage is operated by Univention under
the domain s3.de-west-1.psmanaged.com.
A blob request therefore looks like this:
< HTTP/2 307
< location: https://s3.de-west-1.psmanaged.com/artifacts-software-univention-de/docker/registry/v2/blobs/sha256/.../data?X-Amz-Algorithm=...&X-Amz-Signature=...
The pre-signed URL contains the credentials and an expiry, so no separate
authentication against the storage host is required. The client must, however,
be allowed to follow the redirect to a different domain.
What to configure
- Firewall / proxy allowlist: permit outbound HTTPS (TCP 443) to both
artifacts.software-univention.deands3.de-west-1.psmanaged.com. - HTTP proxies: ensure the proxy forwards (does not block) requests to
s3.de-west-1.psmanaged.comand that it allows cross-host redirects. - TLS-inspecting / MITM proxies: the redirect target uses pre-signed query
parameters. Do not strip or rewrite query strings, and make sure the
proxy’s CA handling does not break the connection to the storage host.
Verifying connectivity
Run the following from a host on the affected network. It fetches an
authentication token, reads a manifest, and downloads the first layer, which is
the request that gets redirected to the storage host. Replace the repository
and reference with one you are entitled to pull.
REGISTRY="https://artifacts.software-univention.de"
REPO="nubus/images/keycloak" # test repository
REF="0.28.1" # tag
# 1. Get a pull token
TOKEN=$(curl -s "${REGISTRY}/service/token?service=harbor-registry&scope=repository:${REPO}:pull" | jq -r '.token')
# 2. Read the manifest and take the first layer digest
DIGEST=$(curl -s \
-H "Authorization: Bearer ${TOKEN}" \
-H "Accept: application/vnd.oci.image.manifest.v1+json" \
"${REGISTRY}/v2/${REPO}/manifests/${REF}" | jq -r '.layers[0].digest')
# 3. Download the layer (this is the request that is redirected to S3)
curl -sS -L -o /dev/null -w "%{http_code}\n" \
"${REGISTRY}/v2/${REPO}/blobs/${DIGEST}"
- A final status of
200means the redirect was followed and the layer
downloaded successfully. - If the layer step hangs or fails while the manifest step (
step 2) works,
the redirect tos3.de-west-1.psmanaged.comis being blocked. Allow that
host and retry.
You can inspect the redirect itself by adding -v and dropping -L; look for
the 307 response and its location header.
Affected scenarios
- Installing or upgrading UCS App Center apps whose images are hosted on
artifacts.software-univention.de(for example Keycloak). - Pulling Nubus / Nubus for Kubernetes container images.
- Any direct
docker pull/skopeo/craneagainst
Note on the previous registry
Older app versions referenced images on docker.software-univention.de.
Newer releases pull from artifacts.software-univention.de. If you previously
only allowed docker.software-univention.de, update your allowlist to the two
hosts in the table above before upgrading.
Related
- Product documentation that references this article from its installation /
prerequisites section. - Nubus Kubernetes operation guide, “Supply chain security”, for verifying
image signatures (Cosign) and reading SBOM / VEX data:
9. Supply chain security — Nubus for Kubernetes - Operation Manual 1.x
