Again problem with letsencrypt updating certificate
After the update of the letsencrypt certificate of my well working UCS (4.4-7 errata945) with Kopano and NextCloud I got this mail:
Refreshing certificate for following domains:
server.mydomain.de
Parsing account key…
Parsing CSR…
Found domains: server.mydomain.de
Getting directory…
Directory found!
Registering account…
Already registered!
Creating new order…
Order created!
Verifying server.mydomain.de…
File “/usr/share/univention-letsencrypt/acme_tiny.py”, line 197, in
main(sys.argv[1:])
File “/usr/share/univention-letsencrypt/acme_tiny.py”, line 193, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, dir$
File “/usr/share/univention-letsencrypt/acme_tiny.py”, line 149, in get_crt
raise ValueError(“Challenge did not pass for {0}: {1}”.format(domain, authorization))
ValueError: Challenge did not pass for server.mydomain.de: {u’status’: u’invalid’, u’challenges’: [{u’status’: u’invalid’, u’val$
Setting letsencrypt/status
Module: kopano-cfg
run-parts: executing /etc/univention/letsencrypt/post-refresh.d//apache2
run-parts: executing /etc/univention/letsencrypt/post-refresh.d//dovecot
run-parts: executing /etc/univention/letsencrypt/post-refresh.d//postfix
What will be the solution?
Heiko
see here: Let's Encrypt fails to renew / verify certificate in UCS 4.4-2 errata-291: traceback error in logfile
in short (allways works for me):
cd /usr/share/univention-letsencrypt
./refresh-cert-cron
Thank you very much for this solution.
Happy Easter
Heiko
I am also experiencing this certificate renewal problem. Today I had once again the issue, that the certificate was invalid.
That happens, if the automatic renewal process fails three times in a row. For me it seems, the monthly update by the cron-script is always failing, but I can’t figure out why.
A while ago, someone of the Univention staff told me, that it might be caused by the time, the script / renewal is executed. If the LE-server is very busy at this time, or something else causes a lag in communication, the renewal request runs into a timeout. Unfortunately, the script doesn’t try again to renew the certificate, if it fails. It will only run again after one month.
To work around this problem, it was suggested, to change the time the cronjob is executed. To do so, you can modify the file /etc/cron.d/univention-letsencrypt
Or much better: directly change the template in /etc/univention/templates/files/etc/cron.d
Otherwise your configuration might be overwritten by an update or a change to the UCR.
If you change “30 3 1 * *” to “44 4 1 * *”, the script will not longer run at 1st of month at 3:30 am, but at 4:44 am.
I also copied the line and added excution times for 2nd and 3rd of month. I think it shouldn’t matter how often you try to renew the certificates, one successful attempt will be enough, even if it is followed by failed attempts.
In three month I will report, if this workaround is working :slight_smile:
Cheers Thorger
A good explanation of the background. Problem recognized problem banned, hopefully.
Heiko
I can give a first feedback -> This is working for me on a server where I have changed the cron-time.
Thank you @Thorger
Best, Bernd
It is a good idea not to change the original univention template but to make a new cron job with an additional date or time so that the system diagnostic don‘t cry.
