After upgrade to ucs 4.2 root volume is mounting read only
after upgrading to the new 4.2 release the server mounts the root partition in read only, I think the problem is the expansion of te root partition in the past
here is a screenshot of my root layout
and fstab
annd uuid’s
does any one have a hint to me to resolv this ?
regards
Christian
Try this command:
mount -t ext4 -o rw,remount -force /dev/sda5/vg_ucs-root /
and then reboot the machine.
This has worked many times for our ucs if it was read only.
regards
Pascalis
You should additionally make sure that the volumes are not “full” - i.e. that there is enough space left.
thanks for the hint but it didn’t work for me :frowning:
rg
Christian
thanks - the volumes are about 50% used so there is enough space free i think
rg
Christian
Hello externa1,
looks like the volume is always mounted with errors so it falls back to ro. You might start in recovery mode and try ‘fsck’.
kind regards
thanks the filesystem is ok
some more info
i found some solutions about this error in the web relating to UUID’s so I changend my fstab for / from /dev/mapper/vg_ucs-root to UUID=8b47f126-80f5-40ab-b0b0-d9e1f4edb824
but that also did not solve this
rg
Christian
Ok i found the problem,
it was the entry in fstab for disabling the MetaBlockCache as suggested in errata 166 for UCS4.1
https://errata.software-univention.de/ucs/4.1/166.html
after removing the no_mbcache entry in fstab its working now
But why ist this happening and how/should I disable mb caching anymore ?
rg
Christian
