After upgrade to 5.0-2 errata492: OX: del key for emails not working anymore
Hello all,
if pressing the del key for deleting emails, nothing happens.
The Firefox console reports following jQuery warning if pressing the del key:
jQuery.Deferred exception: e.e is undefined m@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js line 1 > eval:1:1399
@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js line 1 > eval:1:2046
e@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:29899
Deferred/then/l/</t<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:30223
setTimeout handlerDeferred/then/l/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:30432
i@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:28190
add@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:28494
Deferred/then/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:30528
Deferred@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:30941
then@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:30457
@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js line 1 > eval:1:1721
l/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js line 1 > eval:61:7378
fireWith@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:28958
Deferred/</c[t[0]]@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:30856
execCb@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:487663
check@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:481414
newContext/enable/</<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:483863
bind/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:472512
newContext/emit/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:484315
each@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:471993
emit@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:484286
check@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:482006
enable@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:484190
init@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:480557
a@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:479255
completeLoad@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:486900
h4a.load/o/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:515035
e@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:30171
setTimeout handler
fire@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:28994
l@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:79716
send/r/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:82169
EventHandlerNonNull
send@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:82355
ajax@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:78113
n@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:514825
o@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:515950
require.delayTick/e<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:488711
setTimeout handlerrequire.delayTick@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:488668
require.nextTick@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:488605
i@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:516090
h4a.load/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:516623
setTimeout handler
fileCache.retrieve/</e.onsuccess@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:511159
EventHandlerNonNullfileCache.retrieve/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:511043
setTimeout handler
fileCache.retrieve@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:510808
h4a.load@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:516282
load@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:487616
load@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:481038
fetch@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:480839
check@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:482100
enable@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:486727
newContext/enable/<@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:484047
enable@https://ucs.example.com/appsuite/v=7.10.6-16.20221122.195127/boot.js:1:483547
See Bug 55382 – Update OX 7.10.6 binaries to fix email client
Thank you. This issue is fixed now.
