After upgrading the horde app and univention to the latest release (from 4.3.0 to 4.3.1) I’m getting the following when trying to access the horde app:
A fatal error has occurred
"" driver (for Horde_Auth not found).
Details have been logged for the administrator.
Right now tried to search all the log files for some errors (in- and outside of the docker container) but i can’t seem to find something other than this error.
I’ve installed everything with UCS 4.3.0 and authentication is done with the integrated LDAP Server (or UCS Domain) all installed on a single server.
Where could I look for detailed error description? What could be the missing module? Any help is greatly appreciated!
After some additional tests with a backuped VM I can tell that the reason was not the upgrade of the Univention server itself but the Update of the Horde App. I upgraded from version 5.2.7 to 5.2.17. This Upgrade seems to try to shift as much as possible in the docker container.
Also I can’t investigate it because the horde.log is still empty so I can’t see the debug output of the error (Even if I manually set logging to debung inside the containers /etc/horde/horde/conf.php
I’ve upgraded to Version 5.2.17-2. Before the upgrade version 5.2.7-3 was installed.
Now I’ve tried to reinstall the horde App as suggested but that does not solve my problem. I still get the exact same error.
Here’s a screenshot with the problem I got
Sidenote: I actually did a ssh forwarding directly to the container. That’s why you see localhost:10000 as the address. The error is the same when connecting normally.
Is anybody still checking this ? The upgrade has messed up the calendar sync and I cannot use web mail anymore. Am I supposed to delete the container, reinstall everything and re-enter all of horde’s calendar entries ? Or am I better to use this: https://wiki.univention.de/index.php/Cool_Solution_-_Webcalendar ?
Yes, I know that. But the settings there are correct. It must be something executed afterwards which screws the URL. If I enter http:/horde it throws the a. m. message “Driver for horde_auth not found”.
I guess there is some problem in the upgrade script as I upgraded the same way as the original poster.
May be I should again deinstall, remove the container and reinstall …
However, I have another horde installation which I did not dare upgrading yet. What to do with that one ?
Moritz has shared a detailed list where to look at and eventually how to adjust the configuration in Can't login to Horde after upgrade to last version 5.2.17-1.
I am not sure how the configuration is handled during a re-install and would recommend to check if the hooks.php has the required changes.
I tried it and modified hooks.php as described. In my installation it was line 85 in function “preauthenticate”.
No change in the behaviour, however.
I don’t mind to completely delete the container and set everything up again as this system is not used for business. However I have another installation on which I did not update the horde app yet. And as long as this system does not work I won’t touch the other.
I have tried once to uninstall the Horde app and install it again. In this case the postgresql-db for Horde was re-used and the calendar-entries and contacts came up afterwards.
I tried re-installing the app - this did not help. Again, I’m puzzled that even the link to Horde did not work - even it looks as if it’s configured correctly. Also for this problem re-installing did not help.
Uninstalling a package usually does not purge configurations (from /etc) and LDAP-entries. While the first cleanup can be done with apt (remove --purge) the second means some deeper digging using univention-ldapsearch. I am not very familiar with the Horde integration and dont know where to look at.
The source of the portal entry can be checked with udm settings/portal_entry list --filter=cn=horde.
I get this error if i set horde/auth/driver in the container to “nothing” (empty string), so maybe you could check the value of horde/auth/driver in the horde container
univention-app shell horde ucr get horde/auth/driver
The correct value and the default for this setting is “application”
univention-app shell horde ucr set horde/auth/driver=application
root@lion:~# univention-app shell horde ucr get horde/auth/driver
application
root@lion:~#
Unfortunately I am not at all familiar with this container stuff. Could it be that the update somehow installed a second container and somehow horde is started from the wrong one ? I already re-installed horde which did not change a bit …
-> docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
22580d33364d docker.software-univention.de/ucs-appbox-amd64:4.3-0 "/sbin/init" About an hour ago Up About an hour 0.0.0.0:40000->80/tcp, 0.0.0.0:40001->443/tcp dazzling_joliot
22580d33364d is my horde container, the ID should match the value of the UCR variable appcenter/apps/horde/container
-> ucr get appcenter/apps/horde/container
22580d33364ddd48b3e7705ae3ad235cf96a8f503eff87072b114f87a1bbf018
we see the exactly same problem as described by Martin. All output/file content of the proposed commands is meaningful and matches what’s posted by Felix and Dirk.
Is there any progress on this?
Can 5.2.7 be installed after an upgrade to 5.2.17 (or did the upgrade to 5.2.17 modify the database or whatever that makes 5.2.7 incompatible)? If yes, what’s the procedure to install 5.2.7 again?
What we observed:
Horde test page works despite testdisable being set to true in any config files (all occurences of grep -r testdisable /etc/horde/*). Checking the value in test.php revealed that ‘testdisable’ is not set at all (ie. it’s not false, but unset). So are the config files read at all? I renamed all files in /etc/horde/horde and restarted apache. The only complain was about registry.php. Putting registry.php back makes the system appear as we see it ("" driver (for Horde_Auth not found)).
So quite likely other config files are not processed, what leads to the question how horde starts up and how to trace that?
Besides, the test page shows horde version 5.2.13!? The upgrade worked from command line only (univention-app upgrade horde), from UMC the installation reproducibly failed with error: Unable to find version 5.2.17-2 of app horde.
I did a retry on this matter - to no avail. Every output on the suggested queries seems to be correct:
docker ps
d98b746d91af docker.software-univention.de/ucs-appbox-amd64:4.3-3 "/sbin/init" 13 minutes ago Up 13 minutes 0.0.0.0:40000->80/tcp, 0.0.0.0:40002->443/tcp confident_murdock
bf611ffb1b9d docker.software-univention.de/collabora:4.0.8.2 "/bin/sh -c 'bash st…" 2 hours ago Up 2 hours 0.0.0.0:9980->9980/tcp hopeful_kapitsa
e4881e1facd3 docker.software-univention.de/dudle:1.2 "/start.sh" 6 days ago Up 6 days 0.0.0.0:40001->80/tcp thirsty_poitras
4fe60a11c0a4 docker.software-univention.de/owncloud-owncloud:10.2.1-1 "/usr/bin/entrypoint…" 6 weeks ago Up 9 days 0.0.0.0:40008->8080/tcp owncloud_owncloud_1
0b5780f59110 docker.software-univention.de/owncloud-redis:10.2.1-1 "/usr/bin/entrypoint…" 6 weeks ago Up 9 days 6379/tcp owncloud_redis_1
944d7f38d863 docker.software-univention.de/ucs-appbox-amd64:4.3-0 "/sbin/init" 16 months ago Up 9 days 0.0.0.0:40006->80/tcp musing_goldstine
7ce77cd99a4f docker.software-univention.de/wordpress:4.9.4
d98b746d91af39c0f303e8c046a871becb3aeda5a3ac2c6563150a3979e3b95e
As mentioned already: Removing and reinstalling horde does not help. Clicking on “Open” tries to load horde from “localhost” (which of course fails). If I replace localhost with its dns name the “driver for horde_auth not found” message pops up.
