Admin diary failed installation
After install and see the logs this popup
cat: /etc/mysql.secret: No such file or directory
Enter password: ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
  File "/usr/share/univention-admin-diary/create-tables", line 34, in <module>
    Base.metadata.create_all(get_engine())
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/sql/schema.py", line 3748, in create_all
    tables=tables)
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/engine/base.py", line 1855, in _run_visitor
    with self._optional_conn_ctx_manager(connection) as conn:
  File "/usr/lib/python2.7/contextlib.py", line 17, in __enter__
    return self.gen.next()
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/engine/base.py", line 1848, in _optional_conn_ctx_manager
    with self.contextual_connect() as conn:
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/engine/base.py", line 2039, in contextual_connect
    self._wrap_pool_connect(self.pool.connect, None),
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/engine/base.py", line 2078, in _wrap_pool_connect
    e, dialect, self)
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/engine/base.py", line 1405, in _handle_dbapi_exception_noconnection
    exc_info
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/util/compat.py", line 202, in raise_from_cause
    reraise(type(exception), exception, tb=exc_tb, cause=cause)
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/engine/base.py", line 2074, in _wrap_pool_connect
    return fn()
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/pool.py", line 376, in connect
    return _ConnectionFairy._checkout(self)
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/pool.py", line 713, in _checkout
    fairy = _ConnectionRecord.checkout(pool)
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/pool.py", line 480, in checkout
    rec = pool._do_get()
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/pool.py", line 1060, in _do_get
    self._dec_overflow()
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/util/langhelpers.py", line 60, in __exit__
    compat.reraise(exc_type, exc_value, exc_tb)
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/pool.py", line 1057, in _do_get
    return self._create_connection()
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/pool.py", line 323, in _create_connection
    return _ConnectionRecord(self)
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/pool.py", line 449, in __init__
    self.connection = self.__connect()
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/pool.py", line 607, in __connect
    connection = self.__pool._invoke_creator(self)
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/engine/strategies.py", line 97, in connect
    return dialect.connect(*cargs, **cparams)
  File "/usr/lib/python2.7/dist-packages/sqlalchemy/engine/default.py", line 385, in connect
    return self.dbapi.connect(*cargs, **cparams)
  File "/usr/lib/python2.7/dist-packages/MySQLdb/__init__.py", line 81, in Connect
    return Connection(*args, **kwargs)
  File "/usr/lib/python2.7/dist-packages/MySQLdb/connections.py", line 204, in __init__
    super(Connection, self).__init__(*args, **kwargs2)
sqlalchemy.exc.OperationalError: (_mysql_exceptions.OperationalError) (1045, "Access denied for user 'admindiary'@'localhost' (using password: YES)")
