Address already in use /etc/freeradius/3.0/sites-enabled/default[68]: Error binding to port for 0.0.0.0 port 1812
I’m trying to set wpa2 enterprise but I don’t seem to get freeradius working as intended.
when doing sudo freeradius -X I get this:
Administrator@optiplexmint:~$ sudo freeradius -X
FreeRADIUS Version 3.0.12
Copyright (C) 1999-2016 The FreeRADIUS server project and contributors
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License
For more information about these matters, see the file named COPYRIGHT
Starting - reading configuration files ...
including dictionary file /usr/share/freeradius/dictionary
including dictionary file /usr/share/freeradius/dictionary.dhcp
including dictionary file /usr/share/freeradius/dictionary.vqp
including dictionary file /etc/freeradius/3.0/dictionary
including configuration file /etc/freeradius/3.0/radiusd.conf
including configuration file /etc/freeradius/3.0/proxy.conf
including configuration file /etc/freeradius/3.0/clients.conf
including files in directory /etc/freeradius/3.0/mods-enabled/
including configuration file /etc/freeradius/3.0/mods-enabled/attr_filter
including configuration file /etc/freeradius/3.0/mods-enabled/sradutmp
including configuration file /etc/freeradius/3.0/mods-enabled/replicate
including configuration file /etc/freeradius/3.0/mods-enabled/always
including configuration file /etc/freeradius/3.0/mods-enabled/digest
including configuration file /etc/freeradius/3.0/mods-enabled/realm
including configuration file /etc/freeradius/3.0/mods-enabled/passwd
including configuration file /etc/freeradius/3.0/mods-enabled/files
including configuration file /etc/freeradius/3.0/mods-enabled/pap
including configuration file /etc/freeradius/3.0/mods-enabled/linelog
including configuration file /etc/freeradius/3.0/mods-enabled/ntlm_auth
including configuration file /etc/freeradius/3.0/mods-enabled/ldap
including configuration file /etc/freeradius/3.0/mods-enabled/expr
including configuration file /etc/freeradius/3.0/mods-enabled/preprocess
including configuration file /etc/freeradius/3.0/mods-enabled/detail.log
including configuration file /etc/freeradius/3.0/mods-enabled/soh
including configuration file /etc/freeradius/3.0/mods-enabled/radutmp
including configuration file /etc/freeradius/3.0/mods-enabled/chap
including configuration file /etc/freeradius/3.0/mods-enabled/dynamic_clients
including configuration file /etc/freeradius/3.0/mods-enabled/utf8
including configuration file /etc/freeradius/3.0/mods-enabled/unpack
including configuration file /etc/freeradius/3.0/mods-enabled/mschap
including configuration file /etc/freeradius/3.0/mods-enabled/unix
including configuration file /etc/freeradius/3.0/mods-enabled/expiration
including configuration file /etc/freeradius/3.0/mods-enabled/eap
including configuration file /etc/freeradius/3.0/mods-enabled/logintime
including configuration file /etc/freeradius/3.0/mods-enabled/echo
including configuration file /etc/freeradius/3.0/mods-enabled/exec
including configuration file /etc/freeradius/3.0/mods-enabled/cache_eap
including files in directory /etc/freeradius/3.0/policy.d/
including configuration file /etc/freeradius/3.0/policy.d/moonshot-targeted-ids
including configuration file /etc/freeradius/3.0/policy.d/filter
including configuration file /etc/freeradius/3.0/policy.d/control
including configuration file /etc/freeradius/3.0/policy.d/canonicalization
including configuration file /etc/freeradius/3.0/policy.d/abfab-tr
including configuration file /etc/freeradius/3.0/policy.d/debug
including configuration file /etc/freeradius/3.0/policy.d/dhcp
including configuration file /etc/freeradius/3.0/policy.d/operator-name
including configuration file /etc/freeradius/3.0/policy.d/cui
including configuration file /etc/freeradius/3.0/policy.d/accounting
including configuration file /etc/freeradius/3.0/policy.d/eap
including files in directory /etc/freeradius/3.0/sites-enabled/
including configuration file /etc/freeradius/3.0/sites-enabled/default
including configuration file /etc/freeradius/3.0/sites-enabled/inner-tunnel
main {
 security {
 	user = "freerad"
 	group = "freerad"
 	allow_core_dumps = no
	name = "freeradius"
	prefix = "/usr"
	localstatedir = "/var"
	logdir = "/var/log/freeradius"
	run_dir = "/var/run/freeradius"
main {
	name = "freeradius"
	prefix = "/usr"
	sbindir = "/usr/sbin"
	libdir = "/usr/lib/freeradius"
	radacctdir = "/var/log/freeradius/radacct"
	hostname_lookups = no
	max_request_time = 30
	cleanup_delay = 5
	max_requests = 1024
	pidfile = "/var/run/freeradius/freeradius.pid"
	checkrad = "/usr/sbin/checkrad"
	debug_level = 0
	proxy_requests = yes
 log {
 	stripped_names = yes
 	auth = yes
 	auth_badpass = yes
 	auth_goodpass = no
 	colourise = yes
 	msg_denied = "You are already logged in - access denied"
 resources {
 security {
 	max_attributes = 200
 	reject_delay = 1.000000
 	status_server = yes
radiusd: #### Loading Realms and Home Servers ####
 proxy server {
 	retry_delay = 5
 	retry_count = 3
 	default_fallback = no
 	dead_time = 120
 	wake_all_if_all_dead = no
 home_server localhost {
 	ipaddr = 127.0.0.1
 	port = 1812
 	type = "auth"
 	secret = <<< secret >>>
 	response_window = 20.000000
 	response_timeouts = 1
 	max_outstanding = 65536
 	zombie_period = 40
 	status_check = "status-server"
 	ping_interval = 30
 	check_interval = 30
 	check_timeout = 4
 	num_answers_to_alive = 3
 	revive_interval = 120
  limit {
  	max_connections = 16
  	max_requests = 0
  	lifetime = 0
  	idle_timeout = 0
  coa {
  	irt = 2
  	mrt = 16
  	mrc = 5
  	mrd = 30
 home_server_pool my_auth_failover {
	type = fail-over
	home_server = localhost
 realm example.com {
	auth_pool = my_auth_failover
 realm LOCAL {
radiusd: #### Loading Clients ####
 client 192.168.1.148 {
 	ipaddr = 192.168.1.148
 	require_message_authenticator = no
 	shortname = "192.168.1.148"
  limit {
  	lifetime = 0
  	idle_timeout = 30
Debugger not attached
 # Creating Auth-Type = eap
 # Creating Auth-Type = PAP
 # Creating Auth-Type = CHAP
 # Creating Auth-Type = MS-CHAP
 # Creating Auth-Type = LDAP
radiusd: #### Instantiating modules ####
 modules {
  # Loaded module rlm_attr_filter
  # Loading module "attr_filter.post-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
  attr_filter attr_filter.post-proxy {
  	filename = "/etc/freeradius/3.0/mods-config/attr_filter/post-proxy"
  	key = "%{Realm}"
  	relaxed = no
  # Loading module "attr_filter.pre-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
  attr_filter attr_filter.pre-proxy {
  	filename = "/etc/freeradius/3.0/mods-config/attr_filter/pre-proxy"
  	key = "%{Realm}"
  	relaxed = no
  # Loading module "attr_filter.access_reject" from file /etc/freeradius/3.0/mods-enabled/attr_filter
  attr_filter attr_filter.access_reject {
  	filename = "/etc/freeradius/3.0/mods-config/attr_filter/access_reject"
  	key = "%{User-Name}"
  	relaxed = no
  # Loading module "attr_filter.access_challenge" from file /etc/freeradius/3.0/mods-enabled/attr_filter
  attr_filter attr_filter.access_challenge {
  	filename = "/etc/freeradius/3.0/mods-config/attr_filter/access_challenge"
  	relaxed = no
  # Loading module "attr_filter.accounting_response" from file /etc/freeradius/3.0/mods-enabled/attr_filter
  attr_filter attr_filter.accounting_response {
  	filename = "/etc/freeradius/3.0/mods-config/attr_filter/accounting_response"
  	relaxed = no
  # Loaded module rlm_radutmp
  # Loading module "sradutmp" from file /etc/freeradius/3.0/mods-enabled/sradutmp
  radutmp sradutmp {
  	filename = "/var/log/freeradius/sradutmp"
  	username = "%{User-Name}"
  	case_sensitive = yes
  	check_with_nas = yes
  	permissions = 420
  	caller_id = no
  # Loaded module rlm_replicate
  # Loading module "replicate" from file /etc/freeradius/3.0/mods-enabled/replicate
  # Loaded module rlm_always
  # Loading module "reject" from file /etc/freeradius/3.0/mods-enabled/always
  always reject {
  	rcode = "reject"
  	simulcount = 0
  	mpp = no
  # Loading module "fail" from file /etc/freeradius/3.0/mods-enabled/always
  always fail {
  	rcode = "fail"
  	simulcount = 0
  	mpp = no
  # Loading module "ok" from file /etc/freeradius/3.0/mods-enabled/always
  always ok {
  	rcode = "ok"
  	simulcount = 0
  	mpp = no
  # Loading module "handled" from file /etc/freeradius/3.0/mods-enabled/always
  always handled {
  	rcode = "handled"
  	simulcount = 0
  	mpp = no
  # Loading module "invalid" from file /etc/freeradius/3.0/mods-enabled/always
  always invalid {
  	rcode = "invalid"
  	simulcount = 0
  	mpp = no
  # Loading module "userlock" from file /etc/freeradius/3.0/mods-enabled/always
  always userlock {
  	rcode = "userlock"
  	simulcount = 0
  	mpp = no
  # Loading module "notfound" from file /etc/freeradius/3.0/mods-enabled/always
  always notfound {
  	rcode = "notfound"
  	simulcount = 0
  	mpp = no
  # Loading module "noop" from file /etc/freeradius/3.0/mods-enabled/always
  always noop {
  	rcode = "noop"
  	simulcount = 0
  	mpp = no
  # Loading module "updated" from file /etc/freeradius/3.0/mods-enabled/always
  always updated {
  	rcode = "updated"
  	simulcount = 0
  	mpp = no
  # Loaded module rlm_digest
  # Loading module "digest" from file /etc/freeradius/3.0/mods-enabled/digest
  # Loaded module rlm_realm
  # Loading module "IPASS" from file /etc/freeradius/3.0/mods-enabled/realm
  realm IPASS {
  	format = "prefix"
  	delimiter = "/"
  	ignore_default = no
  	ignore_null = no
  # Loading module "suffix" from file /etc/freeradius/3.0/mods-enabled/realm
  realm suffix {
  	format = "suffix"
  	delimiter = "@"
  	ignore_default = no
  	ignore_null = no
  # Loading module "realmpercent" from file /etc/freeradius/3.0/mods-enabled/realm
  realm realmpercent {
  	format = "suffix"
  	delimiter = "%"
  	ignore_default = no
  	ignore_null = no
  # Loading module "ntdomain" from file /etc/freeradius/3.0/mods-enabled/realm
  realm ntdomain {
  	format = "prefix"
  	delimiter = "\\"
  	ignore_default = no
  	ignore_null = no
  # Loaded module rlm_passwd
  # Loading module "etc_passwd" from file /etc/freeradius/3.0/mods-enabled/passwd
  passwd etc_passwd {
  	filename = "/etc/passwd"
  	format = "*User-Name:Crypt-Password:"
  	delimiter = ":"
  	ignore_nislike = no
  	ignore_empty = yes
  	allow_multiple_keys = no
  	hash_size = 100
  # Loaded module rlm_files
  # Loading module "files" from file /etc/freeradius/3.0/mods-enabled/files
  files {
  	filename = "/etc/freeradius/3.0/mods-config/files/authorize"
  	acctusersfile = "/etc/freeradius/3.0/mods-config/files/accounting"
  	preproxy_usersfile = "/etc/freeradius/3.0/mods-config/files/pre-proxy"
  # Loaded module rlm_pap
  # Loading module "pap" from file /etc/freeradius/3.0/mods-enabled/pap
  pap {
  	normalise = yes
  # Loaded module rlm_linelog
  # Loading module "linelog" from file /etc/freeradius/3.0/mods-enabled/linelog
  linelog {
  	filename = "/var/log/freeradius/linelog"
  	escape_filenames = no
  	syslog_severity = "info"
  	permissions = 384
  	format = "This is a log message for %{User-Name}"
  	reference = "messages.%{%{reply:Packet-Type}:-default}"
  # Loading module "log_accounting" from file /etc/freeradius/3.0/mods-enabled/linelog
  linelog log_accounting {
  	filename = "/var/log/freeradius/linelog-accounting"
  	permissions = 384
  	format = ""
  	reference = "Accounting-Request.%{%{Acct-Status-Type}:-unknown}"
  # Loaded module rlm_exec
  # Loading module "ntlm_auth" from file /etc/freeradius/3.0/mods-enabled/ntlm_auth
  exec ntlm_auth {
  	wait = yes
  	program = "/path/to/ntlm_auth --request-nt-key --domain=MYDOMAIN --username=%{mschap:User-Name} --password=%{User-Password}"
  	shell_escape = yes
  # Loaded module rlm_ldap
  # Loading module "ldap" from file /etc/freeradius/3.0/mods-enabled/ldap
  ldap {
  	server = "optiplexmint.fcortes.local"
  	port = 7389
  	identity = "cn=optiplexmint,cn=dc,cn=computers,dc=fcortes,dc=local"
  	password = <<< secret >>>
   sasl {
   user {
   	scope = "sub"
   	access_positive = yes
    sasl {
   group {
   	filter = "(objectClass=posixGroup)"
   	scope = "sub"
   	name_attribute = "cn"
   	membership_attribute = "memberOf"
   	cacheable_name = no
   	cacheable_dn = no
   client {
   	filter = "(objectClass=radiusClient)"
   	scope = "sub"
   	base_dn = "dc=fcortes,dc=local"
   profile {
   options {
   	ldap_debug = 40
   	chase_referrals = yes
   	rebind = yes
   	net_timeout = 1
   	res_timeout = 10
   	srv_timelimit = 3
   	idle = 60
   	probes = 3
   	interval = 3
   tls {
   	start_tls = yes
Creating attribute LDAP-Group
  # Loaded module rlm_expr
  # Loading module "expr" from file /etc/freeradius/3.0/mods-enabled/expr
  expr {
  	safe_characters = "@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /äéöüàâæçèéêëîïôœùûüaÿÄÉÖÜßÀÂÆÇÈÉÊËÎÏÔŒÙÛÜŸ"
  # Loaded module rlm_preprocess
  # Loading module "preprocess" from file /etc/freeradius/3.0/mods-enabled/preprocess
  preprocess {
  	huntgroups = "/etc/freeradius/3.0/mods-config/preprocess/huntgroups"
  	hints = "/etc/freeradius/3.0/mods-config/preprocess/hints"
  	with_ascend_hack = no
  	ascend_channels_per_line = 23
  	with_ntdomain_hack = no
  	with_specialix_jetstream_hack = no
  	with_cisco_vsa_hack = no
  	with_alvarion_vsa_hack = no
  # Loaded module rlm_detail
  # Loading module "auth_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
  detail auth_log {
  	filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/auth-detail-%Y%m%d"
  	header = "%t"
  	permissions = 384
  	locking = no
  	log_packet_header = no
  # Loading module "reply_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
  detail reply_log {
  	filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/reply-detail-%Y%m%d"
  	header = "%t"
  	permissions = 384
  	locking = no
  # Loading module "pre_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
  detail pre_proxy_log {
  	filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/pre-proxy-detail-%Y%m%d"
  	header = "%t"
  	permissions = 384
  	locking = no
  # Loading module "post_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
  detail post_proxy_log {
  	filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/post-proxy-detail-%Y%m%d"
  	header = "%t"
  	permissions = 384
  	locking = no
  # Loaded module rlm_soh
  # Loading module "soh" from file /etc/freeradius/3.0/mods-enabled/soh
  soh {
  	dhcp = yes
  # Loading module "radutmp" from file /etc/freeradius/3.0/mods-enabled/radutmp
  radutmp {
  	filename = "/var/log/freeradius/radutmp"
  	permissions = 384
  	caller_id = yes
  # Loaded module rlm_chap
  # Loading module "chap" from file /etc/freeradius/3.0/mods-enabled/chap
  # Loaded module rlm_dynamic_clients
  # Loading module "dynamic_clients" from file /etc/freeradius/3.0/mods-enabled/dynamic_clients
  # Loaded module rlm_utf8
  # Loading module "utf8" from file /etc/freeradius/3.0/mods-enabled/utf8
  # Loaded module rlm_unpack
  # Loading module "unpack" from file /etc/freeradius/3.0/mods-enabled/unpack
  # Loaded module rlm_mschap
  # Loading module "mschap" from file /etc/freeradius/3.0/mods-enabled/mschap
  mschap {
  	use_mppe = yes
  	require_encryption = yes
  	require_strong = yes
  	with_ntdomain_hack = yes
  	ntlm_auth = "/usr/bin/univention-radius-ntlm-auth-suidwrapper --request-nt-key --username=%{%{Stripped-User-Name}:-%{%{User-Name}:-None}} --challenge=%{%{mschap:Challenge}:-00} --nt-response=%{%{mschap:NT-Response}:-00} --station-id=%{outer.request:Calling-Station-Id}"
   passchange {
  	allow_retry = yes
  # Loaded module rlm_unix
  # Loading module "unix" from file /etc/freeradius/3.0/mods-enabled/unix
  unix {
  	radwtmp = "/var/log/freeradius/radwtmp"
Creating attribute Unix-Group
  # Loading module "detail" from file /etc/freeradius/3.0/mods-enabled/detail
  detail {
  	filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/detail-%Y%m%d"
  	header = "%t"
  	permissions = 384
  	locking = no
  # Loaded module rlm_expiration
  # Loading module "expiration" from file /etc/freeradius/3.0/mods-enabled/expiration
  # Loaded module rlm_eap
  # Loading module "eap" from file /etc/freeradius/3.0/mods-enabled/eap
  eap {
  	default_eap_type = "peap"
  	timer_expire = 60
  	ignore_unknown_eap_types = no
  	cisco_accounting_username_bug = no
  	max_sessions = 1024
  # Loaded module rlm_logintime
  # Loading module "logintime" from file /etc/freeradius/3.0/mods-enabled/logintime
  logintime {
  	minimum_timeout = 60
  # Loading module "echo" from file /etc/freeradius/3.0/mods-enabled/echo
  exec echo {
  	wait = yes
  	program = "/bin/echo %{User-Name}"
  	input_pairs = "request"
  	output_pairs = "reply"
  	shell_escape = yes
  # Loading module "exec" from file /etc/freeradius/3.0/mods-enabled/exec
  exec {
  	wait = no
  	shell_escape = yes
  	timeout = 10
  # Loaded module rlm_cache
  # Loading module "cache_eap" from file /etc/freeradius/3.0/mods-enabled/cache_eap
  cache cache_eap {
  	driver = "rlm_cache_rbtree"
  	key = "%{%{control:State}:-%{%{reply:State}:-%{State}}}"
  	ttl = 15
  	max_entries = 0
  	epoch = 0
  	add_stats = no
  instantiate {
  # Instantiating module "attr_filter.post-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/post-proxy
  # Instantiating module "attr_filter.pre-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/pre-proxy
  # Instantiating module "attr_filter.access_reject" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/access_reject
[/etc/freeradius/3.0/mods-config/attr_filter/access_reject]:11 Check item "FreeRADIUS-Response-Delay" 	found in filter list for realm "DEFAULT".
[/etc/freeradius/3.0/mods-config/attr_filter/access_reject]:11 Check item "FreeRADIUS-Response-Delay-USec" 	found in filter list for realm "DEFAULT".
  # Instantiating module "attr_filter.access_challenge" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/access_challenge
  # Instantiating module "attr_filter.accounting_response" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/accounting_response
  # Instantiating module "reject" from file /etc/freeradius/3.0/mods-enabled/always
  # Instantiating module "fail" from file /etc/freeradius/3.0/mods-enabled/always
  # Instantiating module "ok" from file /etc/freeradius/3.0/mods-enabled/always
  # Instantiating module "handled" from file /etc/freeradius/3.0/mods-enabled/always
  # Instantiating module "invalid" from file /etc/freeradius/3.0/mods-enabled/always
  # Instantiating module "userlock" from file /etc/freeradius/3.0/mods-enabled/always
  # Instantiating module "notfound" from file /etc/freeradius/3.0/mods-enabled/always
  # Instantiating module "noop" from file /etc/freeradius/3.0/mods-enabled/always
  # Instantiating module "updated" from file /etc/freeradius/3.0/mods-enabled/always
  # Instantiating module "IPASS" from file /etc/freeradius/3.0/mods-enabled/realm
  # Instantiating module "suffix" from file /etc/freeradius/3.0/mods-enabled/realm
  # Instantiating module "realmpercent" from file /etc/freeradius/3.0/mods-enabled/realm
  # Instantiating module "ntdomain" from file /etc/freeradius/3.0/mods-enabled/realm
  # Instantiating module "etc_passwd" from file /etc/freeradius/3.0/mods-enabled/passwd
rlm_passwd: nfields: 3 keyfield 0(User-Name) listable: no
  # Instantiating module "files" from file /etc/freeradius/3.0/mods-enabled/files
reading pairlist file /etc/freeradius/3.0/mods-config/files/authorize
reading pairlist file /etc/freeradius/3.0/mods-config/files/accounting
reading pairlist file /etc/freeradius/3.0/mods-config/files/pre-proxy
  # Instantiating module "pap" from file /etc/freeradius/3.0/mods-enabled/pap
  # Instantiating module "linelog" from file /etc/freeradius/3.0/mods-enabled/linelog
  # Instantiating module "log_accounting" from file /etc/freeradius/3.0/mods-enabled/linelog
  # Instantiating module "ldap" from file /etc/freeradius/3.0/mods-enabled/ldap
rlm_ldap: libldap vendor: OpenLDAP, version: 20445
   accounting {
   	reference = "%{tolower:type.%{Acct-Status-Type}}"
   post-auth {
   	reference = "."
rlm_ldap (ldap): Initialising connection pool
   pool {
   	start = 5
   	min = 3
   	max = 32
   	spare = 10
   	uses = 0
   	lifetime = 0
   	cleanup_interval = 30
   	idle_timeout = 60
   	retry_delay = 30
   	spread = no
rlm_ldap (ldap): Opening additional connection (0), 1 of 32 pending slots used
rlm_ldap (ldap): Connecting to ldap://optiplexmint.fcortes.local:7389
rlm_ldap (ldap): Waiting for bind result...
rlm_ldap (ldap): Bind successful
rlm_ldap (ldap): Opening additional connection (1), 1 of 31 pending slots used
rlm_ldap (ldap): Opening additional connection (2), 1 of 30 pending slots used
rlm_ldap (ldap): Opening additional connection (3), 1 of 29 pending slots used
rlm_ldap (ldap): Opening additional connection (4), 1 of 28 pending slots used
  # Instantiating module "preprocess" from file /etc/freeradius/3.0/mods-enabled/preprocess
reading pairlist file /etc/freeradius/3.0/mods-config/preprocess/huntgroups
reading pairlist file /etc/freeradius/3.0/mods-config/preprocess/hints
  # Instantiating module "auth_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
rlm_detail (auth_log): 'User-Password' suppressed, will not appear in detail output
  # Instantiating module "reply_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
  # Instantiating module "pre_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
  # Instantiating module "post_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
  # Instantiating module "mschap" from file /etc/freeradius/3.0/mods-enabled/mschap
rlm_mschap (mschap): authenticating by calling 'ntlm_auth'
  # Instantiating module "detail" from file /etc/freeradius/3.0/mods-enabled/detail
  # Instantiating module "expiration" from file /etc/freeradius/3.0/mods-enabled/expiration
  # Instantiating module "eap" from file /etc/freeradius/3.0/mods-enabled/eap
   # Linked to sub-module rlm_eap_md5
   # Linked to sub-module rlm_eap_leap
   # Linked to sub-module rlm_eap_gtc
   gtc {
   	challenge = "Password: "
   	auth_type = "PAP"
   # Linked to sub-module rlm_eap_tls
   tls {
   	tls = "tls-common"
   tls-config tls-common {
   	verify_depth = 0
   	ca_path = "/etc/freeradius/3.0/certs"
   	pem_file_type = yes
   	private_key_file = "/etc/freeradius/ssl/private.key"
   	certificate_file = "/etc/freeradius/ssl/cert.pem"
   	ca_file = "/etc/univention/ssl/ucsCA/CAcert.pem"
   	dh_file = "/etc/freeradius/3.0/certs/dh"
   	fragment_size = 1024
   	include_length = yes
   	auto_chain = yes
   	check_crl = no
   	check_all_crl = no
   	cipher_list = "DEFAULT"
   	ecdh_curve = "prime256v1"
    cache {
    	enable = yes
    	lifetime = 24
    	max_entries = 255
    verify {
    	skip_if_ocsp_ok = no
    ocsp {
    	enable = no
    	override_cert_url = yes
    	url = "http://127.0.0.1/ocsp/"
    	use_nonce = yes
    	timeout = 0
    	softfail = no
   # Linked to sub-module rlm_eap_peap
   peap {
   	tls = "tls-common"
   	default_eap_type = "mschapv2"
   	copy_request_to_tunnel = no
   	use_tunneled_reply = no
   	proxy_tunneled_request_as_eap = yes
   	virtual_server = "inner-tunnel"
   	soh = no
   	require_client_cert = no
tls: Using cached TLS configuration from previous invocation
   # Linked to sub-module rlm_eap_mschapv2
   mschapv2 {
   	send_error = no
  # Instantiating module "logintime" from file /etc/freeradius/3.0/mods-enabled/logintime
  # Instantiating module "cache_eap" from file /etc/freeradius/3.0/mods-enabled/cache_eap
rlm_cache (cache_eap): Driver rlm_cache_rbtree (module rlm_cache_rbtree) loaded and linked
 } # modules
radiusd: #### Loading Virtual Servers ####
server { # from file /etc/freeradius/3.0/radiusd.conf
} # server
server default { # from file /etc/freeradius/3.0/sites-enabled/default
 # Loading authenticate {...}
 # Loading authorize {...}
 # Loading preacct {...}
 # Loading accounting {...}
Ignoring "sql" (see raddb/mods-available/README.rst)
 # Loading post-proxy {...}
 # Loading post-auth {...}
} # server default
server inner-tunnel { # from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
 # Loading session {...}
} # server inner-tunnel
radiusd: #### Opening IP addresses and Ports ####
listen {
  	type = "auth"
  	ipaddr = *
  	port = 0
   limit {
   	lifetime = 0
   	idle_timeout = 30
Failed binding to auth address * port 1812 bound to server default: Address already in use
Actions take
  • reading online about the error at the end says that port 1812 is being used elsewhere therefore I need to ensure that it’s not use so freeradius can bind to it. but I can’t seem to find what service is holding on that port that is not freeradius itself
Administrator@optiplexmint:~$ sudo lsof -i:1812
COMMAND    PID    USER   FD   TYPE  DEVICE SIZE/OFF NODE NAME
freeradiu 5683 freerad   12u  IPv4 2234889      0t0  UDP *:radius
freeradiu 5683 freerad   14u  IPv6 2234891      0t0  UDP *:radius
I tried to stop the service and restart it but same debug from freeradius
Any ideas?
Hey,
How did you try to stop the running service? Use this:
# Stop the service:
systemctl stop freeradius.service
# Make sure systemd thinks it isn't running (see line "Active:"):
systemctl status freeradius.service
# Verify it isn't still running from outside of systemd's managed scope:
lsof -Pni:1812
If it is still running in step 3, simply send all mentioned PIDs the command to terminate: kill <PID1> <PID2>… If they persist, use kill -9 <PID1>…
m.
Hi Moritz
Thank you for your reply
to answer your questions I was using
sudo freeradius stop,
so I gave it a try with systemclt as you suggested but eventhough I see the service was fully stop and there was no process latched to port 1812, once I restart freeradius and test it with -X I’m still getting the same error binding message: here’s what I did:
Administrator@optiplexmint:~$ sudo systemctl stop freeradius.service
Administrator@optiplexmint:~$ sudo systemctl status freeradius.service
● freeradius.service - FreeRADIUS multi-protocol policy server
   Loaded: loaded (/lib/systemd/system/freeradius.service; enabled; vendor preset: enabled)
   Active: inactive (dead) since Thu 2018-06-28 23:40:52 EDT; 23s ago
     Docs: man:radiusd(8)
           man:radiusd.conf(5)
           http://wiki.freeradius.org/
           http://networkradius.com/doc/
  Process: 10196 ExecStart=/usr/sbin/freeradius $FREERADIUS_OPTIONS (code=exited, status=0/SUCCESS)
  Process: 10194 ExecStartPre=/usr/sbin/freeradius $FREERADIUS_OPTIONS -Cxm -lstdout (code=exited, status=0/SUCCESS)
 Main PID: 10200 (code=exited, status=0/SUCCESS)
      CPU: 185ms
Jun 28 23:39:13 optiplexmint freeradius[10194]: rlm_mschap (mschap): authenticating by calling 'ntlm_auth'
Jun 28 23:39:13 optiplexmint freeradius[10194]: tls: Using cached TLS configuration from previous invocation
Jun 28 23:39:13 optiplexmint freeradius[10194]: rlm_cache (cache_eap): Driver rlm_cache_rbtree (module rlm_cache_rbtree
Jun 28 23:39:13 optiplexmint freeradius[10194]: Ignoring "sql" (see raddb/mods-available/README.rst)
Jun 28 23:39:13 optiplexmint freeradius[10194]: radiusd: #### Skipping IP addresses and Ports ####
Jun 28 23:39:13 optiplexmint freeradius[10194]: Configuration appears to be OK
Jun 28 23:39:13 optiplexmint freeradius[10194]: rlm_ldap (ldap): Removing connection pool
Jun 28 23:39:13 optiplexmint systemd[1]: Started FreeRADIUS multi-protocol policy server.
Jun 28 23:40:52 optiplexmint systemd[1]: Stopping FreeRADIUS multi-protocol policy server...
Jun 28 23:40:52 optiplexmint systemd[1]: Stopped FreeRADIUS multi-protocol policy server.
Administrator@optiplexmint:~$ sudo lsof -Pni:1812
Administrator@optiplexmint:~$ sudo systemctl start freeradius.service
} # server default
listen {
  	type = "auth"
  	ipaddr = *
  	port = 0
   limit {
   	lifetime = 0
   	idle_timeout = 30
any other suggestions?
Hey,
freeradius stop is definitely not the correct way to stop a service.
if systemctl status… says it’s stopped, but there’s still a process running, then it’s one not under control of systemd. Kill that process manually like I’ve explained in my first.
m.
Hi Moritz
Again, thank you for getting back to me and for your patience.
indeed, I stopped the service as you indicated and doing sudo lsof -Pni:1812 shows no service using that port.
when I restart the service, also with systemctl as you indicated, I check for processes working with port 1812, the only service on that port appears to be freeradius
Administrator@optiplexmint:~$ sudo netstat -tulpn | grep "1812"
udp        0      0 127.0.0.1:18120         0.0.0.0:*                           30985/freeradius
udp        0      0 0.0.0.0:1812            0.0.0.0:*                           30985/freeradius
udp6       0      0 :::1812                 :::*                                30985/freeradius
freeradiu 30985 freerad   12u  IPv4 5649699      0t0  UDP *:1812
freeradiu 30985 freerad   14u  IPv6 5649701      0t0  UDP *:1812
yet, for some reason freeradius debug mode still shows me the binding error.
Actions taken
  1. I’ve tried looking for any other processes latched on 1812 with
    sudo lsof -Pni:1812
    netstat -tulpn | grep :80
    fuser 1812/udp
    but again the only process that comes up is freeradius’ if started or none if stopped.
  2. I un-installed the radius module from the gui console, checked for processes on 1812 and nothing. Then I proceeded to install again the radius module, configure again clients.conf and restarted the service, but again when checking on debug mode expecting to find the message that says that freeradius is waiting on request… I then again get the same error message reported in this post.
what am I missing?
thank you.
You cannot have freeradius running when trying to start it in debugging mode. In debugging mode, it will start a new server and act just like a regular server, just with a lot more logging. It doesn’t try to switch an already running instance into debug mode, no, it tries to start a new one.
You have to stop all running instances of freeradius. Do not try to start it again with systemctl (and I never told you to do that, BTW). Then, and only then, run freeradius in debug mode.
That’s what I was missing/misunderstanding… thank you so much Moritz for your clarification and patience. newbie here.
Cheers
