Hi Folks,
after installation of nextcloud App there is nc-admin and Administrator part of the “admin” group.
Is it possible to add additional users to this group? Adding users to “Administrator” does not help…
thanx
Hi Folks,
thanx
Yes, it is possible, You need to add the users to the admin group inside Nextcloud as this is a local group…
hth,
Dirk
Hi Dirk,
sorry - but how to achieve this? As the users come from the ldap I have no option to modify the groups from a user. Adding users to the admin group is also not possble and the group “admin” does not exist in the UCS ldap…
hmmm… do I miss a detail?
cheers,
Mat
Anyone have a solution for this?
In NC 20 the handling of users is different to previous versions.
Click on pencil next to right border in the line of the user (1) the “Group” field changes its layout (2)
Click in the field and then on “Admin” (3).
The Admin should be added then (4) and the pencil switched to a checkmark.
Finally click on the checkmark.
