Adding DNS record for a type that does not exist
I need to add a dns record type URI but it’s not in the drop down menu. Is there a possibility to add DNS types or some other ways to add DNS records with types that are not supported?
Hey,
other resource types than A, AAAA, PTR, CNAME, TXT, SRV are not supported and cannot be managed in a UCS domain.
One thing you might be able to do is to create a manually managed zone, add your record there and add a CNAME (alias) in your UCS-managed zone to the name in the manually managed zone.
Kind regards,
mosu
Ok in that case, as I need to add URI then I can work around this problem by installing an apache server that does the redirect.
