Im using a separate system for my WiFi Portal and want to centralized Authentication on UCS,
I have already setup a working connection to authenticate user with my radius and ldap support with ucs,
How can I add radius attribute to ucs for radius like WISPr- Bandwidth-Max-Down, WISPr-Bandwidth -Max-Up and WISPr-Redirection-URL?
Is this possible?
could you guide me how to do this.
Thanks.
Hello @macky007,
You can use the already existing UniventionFreeAttributes for that.
This Wiki article explains the use: https://wiki.univention.de/index.php/Cool_Solution_-_User_Self-Service_with_extended_Attributes
BR,
Jörn
Thank you very much for this hint. I needed to add custom attributes so that I can control which user has which permissions on a Mikrotik router after a successful RADIUS authentication.
I have documented the whole process here: https://lcx.wien/blog/mikrotik-freeradius-on-ucs/ really hope this helps others as well.
