I am currently testing UCS as a possible alternative to Active Directory + Openldap.
When I create a user and set the “User has to change password on next login” tag, the password change fails in Lubuntu 18.04 because the dictionary cannot be loaded.
Would it be possible to add libpam-cracklib (the dictionary in question) as a dependency of univention-domain-join, so it is installed at the same time?
Regards,
