Add fonts to use with OnlyOffice
I use OnlyOffice & Owncloud in my UCS environment. A good combination! Now I would like to add a (TTF or other) font to use in OnlyOffice. Is there an easy way to do this in UCS? Or a less easy way?
Tnx, Richard
Hi Richard,
look at https://helpcenter.onlyoffice.com/de/server/linux/document/install-fonts.aspx. This also should be good for OwnCloud
Regards
Hi! Tnx for your suggestion. I’ve seen that solution as well, the only thing is that I can’t find the documentserver-generate-allfonts.sh in the /usr/bin folder. Should I find a copy of that .sh file and put it in the /usr/bin folder?
Regards
Hi
Onlyoffice is installed as a docker app - so you’ll have to this inside the docker container.
on the host type docker ps to list your container the you’ll access it through
docker exec -it container_name bash
there you’ll find the documentserver-generate-allfonts.sh script in /usr/bin
rg
Christian
Hello @richardw,
there is a shortcut to enter the shell in a Docker based app: univention-app shell onlyoffice. It does the same as describe by @externa1: Find the container ID of the ONLYOFFICE Docker container and then execute docker exec -it container_id bash.
Best regards,
Nico
Thanks everybody, it works!
I managed to copy the ttf files to the docker using ‘docker cp’ and execute the documentserver-generate-allfonts.sh script in /usr/bin (in the docker).
Regards,
Richard
one should add that these steps would need to be re-done with each update of the app since the changes are only done inside of the container (which is discarded on upgrade).
