AD Member Passwort Problem
Hier ist ebenfalls die AD Anbindung defekt, kurz nach UCS5 Upgrade
Der zieht das Passwort aus ner Temp Datei?
root@ucs01:~# kinit --no-addresses --password-file=/etc/machine.secret ucs01$
kinit: Password incorrect
geht auch nicht.
Wie geh ich da am besten vor?
  File "/usr/lib/python3/dist-packages/univention/connector/ad/main.py", line 247, in main
    connect(options)
  File "/usr/lib/python3/dist-packages/univention/connector/ad/main.py", line 119, in connect
    ad.init_ldap_connections()
  File "/usr/lib/python3/dist-packages/univention/connector/ad/__init__.py", line 543, in init_ldap_connections
    self.open_ad()
  File "/usr/lib/python3/dist-packages/univention/connector/ad/__init__.py", line 700, in open_ad
    self.get_kerberos_ticket()
  File "/usr/lib/python3/dist-packages/univention/connector/ad/__init__.py", line 677, in get_kerberos_ticket
    raise kerberosAuthenticationFailed('The following command failed: "%s" (%s): %s' % (' '.join(cmd_block), p1.returncode, stdout.decode('UTF-8', 'replace')))
univention.connector.ad.kerberosAuthenticationFailed: The following command failed: "kinit --no-addresses --password-file=/tmp/tmp4flindvm ucs01$" (1): kinit: Password incorrect
