AD- Connector Zertifikatsfehler
Guten Tag,
[quote]Fri Mar 19 13:45:35 2010
— connect failed, failure was: —
File “/usr/lib/python2.4/site-packages/univention/connector/ad/main.py”, line 216, in main
connect()
File “/usr/lib/python2.4/site-packages/univention/connector/ad/main.py”, line 142, in connect
ad_ldap_bindpw, baseConfig[‘connector/ad/ldap/certificate’], baseConfig[‘connector/ad/listener/dir’])
File “/usr/lib/python2.4/site-packages/univention/connector/ad/init.py”, line 565, in init
self.lo_ad=univention.uldap.access(host=ad_ldap_host, port=int(ad_ldap_port), base=ad_ldap_base, binddn=ad_ldap_binddn, bindpw=ad_ldap_bindpw, start_tls=
2, ca_certfile=ad_ldap_certificate, decode_ignorelist=[‘objectSid’, ‘objectGUID’, ‘repsFrom’, ‘replUpToDateVector’, ‘ipsecData’, ‘logonHours’, ‘userCertifica
te’, ‘dNSProperty’, ‘dnsRecord’, ‘member’])
File “/usr/lib/python2.4/site-packages/univention/uldap.py”, line 115, in init
self.__smart_open()
File “/usr/lib/python2.4/site-packages/univention/uldap.py”, line 137, in __smart_open
self.lo=ldap.ldapobject.SmartLDAPObject(uri=“ldap://”+str(self.host)+":"+str(self.port), start_tls=self.start_tls, tls_cacertfile=self.ca_certfile)
File “/usr/lib/python2.4/site-packages/ldap/ldapobject.py”, line 861, in init
self.start_tls_s()
File “/usr/lib/python2.4/site-packages/ldap/ldapobject.py”, line 762, in start_tls_s
res = SimpleLDAPObject.start_tls_s(self)
File “/usr/lib/python2.4/site-packages/ldap/ldapobject.py”, line 505, in start_tls_s
return self._ldap_call(self._l.start_tls_s)
File “/usr/lib/python2.4/site-packages/ldap/ldapobject.py”, line 94, in _ldap_call
result = func(*args,**kwargs)
CONNECT_ERROR: {‘info’: ‘Error in the certificate.’, ‘desc’: ‘Connect error’}´[/quote]
Verwende einen Windows 2003 Server… Zertifikate wurden in beide Richtungen kopiert, univention-adsearch funktioniert prima…
Woran liegts??
danke!
welche UCS Version wird eingesetzt und mit welcher Architektur ist der Server installiert(amd64|i386)? Welche Zertifikatsdatei wurde genau kopiert?
Mit freundlichen Grüssen
Tobias Scherer
UCS Server:
[quote]root@ucstom:~# uname -a
Linux ucstom 2.6.18-ucs105-686 #1 SMP Fri Feb 6 21:01:18 UTC 2009 i686 GNU/Linux[/quote]
Windows Server 2003 SP1 32 Bit wird als AD- Gegenstelle benutzt.
Am Windows Server 2003 wurde die Zertifikatsstelle installiert und das Zertifikat im DER Format .cer exportiert und im UCS hochgeladen…
Gibts keine Lösungsvorschläge :-(?
welche UCS Version wird aktuell eingesetzt?
ucr search ^version
Wurde das Rechnerzertifikat aus "/etc/univention/ssl/" auf den AD Server exportiert?
Wurde das Rechnerzertifikat vom Windowshost korrekt auf den UCS Server exportiert und die UCR-Variable “connector/ad/ldap/certificate” korrekt gesetzt? Hier muss der vollständige Pfad zur vom AD Server exportierten Zertifikatsdatei enthalten sein.
Mit welchem Benutzer wird die Synchronisation durchgeführt?
In welche Richtung wird Synchronisiert?
ucr get  connector/ad/mapping/syncmode
Ggf. hilft es die Schritte des Zertifikatsexports nocheinmal wie in diesem Dokument beschrieben durchzuführen.
Tobias Scherer
[quote]root@ucstom:~# ucr search ^version
version/patchlevel: 3
version/releasename: copper beech
version/security-patchlevel: 0
version/version: 2.2[/quote]
Habe nun nochmals alles von Anfanfg an gemacht:
1.) Am Windows 2003 angemeldet und über die Zert.-Stelle das Zertifikat exportiert (cert.cer hab ichs genannt).
2.) cert.cer am ucs kopiert und Befehl ausgeführt:
openssl x509 -inform der -outform pem -in cert.cer -out wincert.pem
3.) Dan in die Registry gesetzt:
univention-config-registry set connector/ad/ldap/certificate=/root/wincert.pem
root@ucstom:~# ucr get connector/ad/mapping/syncmode read
Und wird als Benutzer root durchgeführt…
Selber fehler :frowning:
Lg
mit welchem Benutzer wird zur Synchronisation auf dem AD angemeldet?
ucr get connector/ad/ldap/binddn
Wie sind die Berechtigungen auf das Zertifikat?
Wenn Sie das Zertifikat wie folgt ablegen und den AD Connector neustarten, verbessert sich das Verhalten?
cp /root/wincert.pem /etc/univention/connector/
chmod +r /etc/univention/connector/wincert.pem
ucr set connector/ad/ldap/certificate=/etc/univention/connector/wincert.pem
Tobias Scherer
root@ucstom:~# ucr get connector/ad/ldap/binddn
cn=Administrator,cn=users,DC=scalixlab,DC=local
Und immer noch gleicher fehler…
lg
können Sie folgende Schritte bitte nocheinmal wiederholen.
Das Zertifikat vom Active Dirctory System auf das UCS System kopieren:
Zertifizierungsstelle -> AD-Domäne -> Eigenschaften -> Zertifikat anzeigen -> Details -> In Datei kopieren -> DER-codiert-binaer X.509F
Über das UMC Modul zur Active Directory Connector Einrichtung mit
Active Directory-Zertifikat hochladen -> Durchsuchen -> Datei Auswählen -> Hochladen -> Speichern
das Zertifikat auf das UCS System laden.
Dann überprüfen Sie bitte den Speicherort, die Berechtigungen der Zertifikatsdatei sowie die korrekte Angabe des Speicherorts in der UCR-Variable “connector/ad/ldap/certificate” .
Tobias Scherer
ich hatte heute das selbe Problem.
Die Fehlermeldung ist genau die gleiche, und ich habe lediglich ein Update durchgefuehrt.
Vorher installiert war: 2.2-4-4
Update ist: 2.2-5
Natuerlich hab ich an den Zertifikaten nichts geaendert.
Anschliessend bin ich auf einen Snapshot vor dem Update gewechselt, dann funktioniert der AD-Connector wieder einwandfrei.
Hallo nochmal,
ich habe rausgefunden woran es liegt:
Es wurde unter anderem die Datei
geupdated.
Mit der Version von 2.2-4 funktioniert der AD-Connector, mit 2.2-5 nicht.
Es wird jetzt scheinbar versucht mit TLS auf den LDAP zuzugreifen.
[quote]136c136,138
< self.lo=ldap.ldapobject.SmartLDAPObject(uri=“LDAP://”+str(self.host)+":"+str(self.port), who=self.binddn, cred=self.__encode_pwd(self.bindpw), start_tls=self.start_tls, tls_cacertfile=self.ca_certfile)
          ldap.set_option( ldap.OPT_X_TLS_CACERTFILE, self.ca_certfile )
          self.lo=ldap.ldapobject.SmartLDAPObject(uri="ldap://"+str(self.host)+":"+str(self.port), start_tls=self.start_tls, tls_cacertfile=self.ca_certfile)
          self.lo.simple_bind_s(self.binddn, self.__encode_pwd(self.bindpw))
142c144
< self.lo=ldap.initialize(“LDAP://”+str(self.host)+":"+str(self.port))
          self.lo=ldap.initialize("ldap://"+str(self.host)+":"+str(self.port))[/quote]
Allerdings wuesste ich nicht warum das nicht gehen sollte.
Muss dazu auf AD-Seite erst etwas aktiviert werden ?
Der Zugriff per SSL auf Port 636 funktioniert jedoch.
zur Verbesserung dieses Verhaltens wurde ein Update für UCS 2.3-1 herausgegeben. Zu UCS 2.3-2 wurde dieses Verhalten direkt verbessert. Weitere Informationen dazu sind in diesem SDB Artikel und diesem Eintrag in unserem Bug Tracking System zu finden.
Tobias Scherer
Mastodon
