habe unter UCS 2.4 versucht, den AD Connector einzurichten. Das Ermitteln der BasisDN hat nach der Eingabe des Rechnernamen ohne Probleme funktioniert. Beim Speichern der Einstellungen folgt jedoch immer dieser Fehler:
Ein Fehler ist aufgetreten
Die Ausführung des Kommandos ‘adconnector/configure’ ist fehlgeschlagen:
File “/usr/lib/python2.4/site-packages/univention/management/console/handlers/init.py”, line 160, in execute
func( object )
File “/usr/lib/python2.4/site-packages/univention/management/console/handlers/adconnector/init.py”, line 214, in configure
univention.config_registry.handler_set( [ u’%s=%s’ % (ucrkey, val) ] )
File “/usr/lib/python2.4/site-packages/univention/config_registry.py”, line 903, in handler_set
reg.save()
File “/usr/lib/python2.4/site-packages/univention/config_registry.py”, line 130, in save
self._registry[ self._write_registry ].save()
File “/usr/lib/python2.4/site-packages/univention/config_registry.py”, line 293, in save
self.__save_file(filename)
File “/usr/lib/python2.4/site-packages/univention/config_registry.py”, line 278, in __save_file
fp.write(self.str())
File “/usr/lib/python2.4/site-packages/univention/config_registry.py”, line 314, in str
return ‘\n’.join([’%s: %s’ % (key, self.removeInvalidChars (val)) for key, val in self.items()])
File “/usr/lib/python2.4/encodings/utf_8.py”, line 16, in decode
return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: ‘utf8’ codec can’t decode bytes in position 11-12: invalid data
