I recently updated a UCS system consisting of 2 servers, members of existing AD domain, from version 4.2 to 4.3 (as systems reported the version is “out of maintenance”).
The UCS DC Master has the AD Connector installed and running.
It is/was all running “normally” until after a few days I noticed the UCS systems don’t get/reflect any changes made in AD (no new groups, memberships, users…)
The servers seems working “normally”, you can authenticate, use resources… just no “updates/changes” coming from AD…
The connector-status.log reports:
--- connect failed, failure was: ---
File "/usr/share/pyshared/univention/connector/ad/main.py", line 303, in main
connect()
File "/usr/share/pyshared/univention/connector/ad/main.py", line 191, in connect
baseConfig['%s/ad/listener/dir' % CONFIGBASENAME]
File "/usr/lib/pymodules/python2.7/univention/connector/ad/__init__.py", line 837, in __init__
self.open_ad()
File "/usr/lib/pymodules/python2.7/univention/connector/ad/__init__.py", line 1038, in open_ad
self.lo_ad.lo.sasl_interactive_bind_s("", auth)
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 962, in sasl_interactive_bind_s
res = self._apply_method_s(SimpleLDAPObject.sasl_interactive_bind_s,*args,**kwargs)
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 931, in _apply_method_s
return func(self,*args,**kwargs)
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 244, in sasl_interactive_bind_s
return self._ldap_call(self._l.sasl_interactive_bind_s,who,auth,RequestControlTuples(serverctrls),RequestControlTuples(clientctrls),sasl_flags)
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 106, in _ldap_call
result = func(*args,**kwargs)
LOCAL_ERROR: {'info': 'SASL(-1): generic failure: GSSAPI Error: Unspecified GSS failure. Minor code may provide more information (Server not found in Kerberos database)', 'desc': 'Local error'}
the same error is reported by univention-adsearch
but, net ads testjoin reports all ok
kinit/klist seems working OK
net ads info works ok
LDAP server: 172.16.0.180
LDAP server name: DC01.sih.net
Realm: SIH.NET
Bind Path: dc=SIH,dc=NET
LDAP port: 389
Server time: Sat, 20 Oct 2018 12:49:18 CEST
KDC server: 172.16.0.180
Server time offset: 0
Last machine account password change: Sat, 20 Oct 2018 01:49:06 CEST
net ads status fails
root@ucs-master:~# net ads status
gse_get_client_auth_token: gss_init_sec_context failed with [ Miscellaneous failure (see text): KDC has no support for encryption type](2529638926)
Enter root's password:
ads_connect: No logon servers are currently available to service the logon request.
kerberos_kinit_password root@SIH.NET failed: Client not found in Kerberos database
Did the net ads status after kinit Administrator and entered the password.
The “KDC has no support for encryption type](2529638926)” seems suspicious… but I do not know what changed?? Which KDC does not support which encryption? (local? AD?)
The current AD is still a Windows 2003 domain and the “primary” AD DC is still a Windows 2003 server… if that could be the reason…
I tried to deinstall the AD Conenctor and reinstall it again - hoping the “config wizard” will re-join/re-configure the AD connection but “nothing happened” - all the “config” was already there and I had no chance to reconfigure anything.
What can be done?! How to (manually) re-join/reconfigure the AD connector and hopefully resolve the issue?
Regards,
M.Culibrk
