AD-Connector does not sync anymore
after a failed Takeover my System does not sync AD anymore.
Problem, I have Kopano running and need the AD.
Whats the best Practice to get AD Connector running again?
Cheers Chriz
Okt 09 18:40:34 UCS python2.7[2140]: **GSSAPI Error: Unspecified GSS failure. Minor code may provide more …tabase)**
Server not found in Kerberos database
Static Host and LDAP Name changed
No Errors anymore in connector.log
But does not update users
any idea?
after hours here the old solution, i remember
https://help.univention.com/t/speed-up-ldap-binds-on-ad-member-mode-systems/41
Hi Christian,
so does this solution solved your issue?
Cheers Nico
yes, nico. after running that sync worked again.
for further people
if you change your dc, change name and create a fixed variable for your new dc on ad member machine. perhaps use kinit administrator to rejoin and check connector.log for working
thanks
