Accidentally edit /etc/machine.secret
Hi
I have problem with /etc/machine.secret becasue I try to fix my adconnector and I accidentally edit /etc/machine.secret, right now I can not login as root or administrator on Univention management and can’t login OX Appsuite
I try to univention-ldapsearch
Out put is
root@email:~# univention-ldapsearch
ldap_bind: Invalid credentials (49)
root@email:~#
I try
udm computers/domaincontroller_master modify \
 --dn "$(ucr get ldap/hostdn)" --set password="$pass"
echo -n "$pass" >/etc/machine.secret
echo "$pass" >/etc/libnss-ldap.secret
But still not working
Is there any solution to regenerate /etc/machine.secret
Thank you
Best regards
did your try to reset the password for the users “root” and “Administrator” with the udm command?
I doubt it will work as your above command indeed are correct and should work.
What does ucr get ldap/hostdn say?
/CV
Not yet try to reset password
I try again
ldap_bind: Server is unwilling to perform (53)
        additional info: unauthenticated bind (DN with no password) disallowed
It seem no password in machine.secret
root@email:~# ucr get ldap/hostdn
cn=email,cn=dc,cn=computers,dc=pluscard,dc=com
Thank you
try to run the join script again which usually creates the machine.secret:
univention-run-join-scripts --ask-pass -dcaccount administrator --force --run-scripts 10univention-ldap-server.inst
If this does not work, do the following:
password="1234QWERasdf"
udm computers/domaincontroller_master modify --dn "$(ucr get ldap/hostdn)" --set password=$password
echo -n $password > /etc/machine.secret
chmod 0600 /etc/machine.secret
If this does not work I am out of options or there might be some additional issue on your system.
/CV
It asks for DC Master Password where I can fiind the password?
Well, this is the password you assigned during installation.
The password of your user “Administrator”.
If you forgot this, too you might need to acquire some more experience in administrating server operation systems.
Otherwise you have a chance to reset by this way:
First, get DN of administrator:
root@master:~# udm users/user list --filter uid=Administrator | grep "DN:"
DN: uid=Administrator,cn=users,dc=multi,dc=de
Use this dn to reset the password for the account:
root@master:~# udm users/user modify --dn="uid=Administrator,cn=users,dc=multi,dc=ucs" --set password="never_before_used_password"
/CV
result is
root@email:~# univention-run-join-scripts --ask-pass -dcaccount administrator --force --run-scripts 10univention-ldap-server.inst
Enter DC Master Password:
Search LDAP binddn Permission denied (publickey,gssapi-keyex,gssapi-with-mic,keyboard-interactive).
* Running join scripts failed!                                           *
* Message:  binddn for user administrator not found
I use Root passord for DC Master Password
root@email:~# udm users/user modify --dn="uid=Administrator,cn=users,dc=pluscard,dc=com" --set password="NewPassword"
Value may not change: key=password old={KINIT} new=NewPassword
root@email:~#
Result
root@email:~# password="1234QWERasdf"
root@email:~# udm computers/domaincontroller_master modify --dn $(get ldap/hostdn) --set password=$password
-bash: get: command not found
LDAP Error: Invalid DN syntax: invalid DN: --set
root@email:~# echo -n $password > /etc/machine.secret
root@email:~# chmod 0600 /etc/machine.secret
my fault. Typo.
Use:
It works now for login UMC management for Root and Administrator user but I can’t login into OX Appsuite
I have no clue about OX.
Possibly you might need to re-run the join scripts?
univention-run-join-scripts --force
/CV
EDIT:
Objection!
You are not supposed to do a
on a DC master /primary! This will cause more damage than it heals
There are two failed and still not work
root@email:~# univention-run-join-scripts --force
copyright (c) 2001-2018 Univention GmbH, Germany
Running 01univention-ldap-server-init.inst                 done
Running 02univention-directory-notifier.inst               done
Running 03univention-directory-listener.inst               done
Running 04univention-ldap-client.inst                      done
Running 05univention-bind.inst                             done
Running 08univention-apache.inst                           done
Running 10univention-ldap-server.inst                      failed (exitcode: 3)
Running 11univention-heimdal-init.inst                     done
Running 11univention-pam.inst                              done
Running 15univention-directory-notifier-post.inst          done
Running 15univention-heimdal-kdc.inst                      done
Running 18python-univention-directory-manager.inst         done
Running 20univention-directory-policy.inst                 done
Running 20univention-join.inst                             done
Running 26univention-nagios-common.inst                    done
Running 26univention-samba.inst                            failed (exitcode: 2)
Running 30univention-appcenter.inst                        done
Running 30univention-nagios-client.inst                    done
Running 31univention-nagios-ad-connector.inst              done
Running 33univention-portal.inst                           done
Running 34univention-management-console-server.inst        done
Running 34univention-self-service.inst                     done
Running 35univention-appcenter-docker.inst                 done
Running 35univention-management-console-module-adconnector.done
Running 35univention-management-console-module-appcenter.indone
Running 35univention-management-console-module-diagnostic.idone
Running 35univention-management-console-module-ipchange.insdone
Running 35univention-management-console-module-join.inst   done
Running 35univention-management-console-module-lib.inst    done
Running 35univention-management-console-module-mrtg.inst   done
Running 35univention-management-console-module-pkgdb.inst  done
Running 35univention-management-console-module-quota.inst  done
Running 35univention-management-console-module-reboot.inst done
Running 35univention-management-console-module-services.insdone
Running 35univention-management-console-module-setup.inst  done
Running 35univention-management-console-module-sysinfo.instdone
Running 35univention-management-console-module-top.inst    done
Running 35univention-management-console-module-ucr.inst    done
Running 35univention-management-console-module-udm.inst    done
Running 35univention-management-console-module-updater.instdone
Running 35univention-self-service-passwordreset-umc.inst   done
Running 35univention-server-overview.inst                  done
Running 36univention-management-console-module-apps.inst   done
Running 38univention-management-console-module-oxldb.inst  done
Running 40univention-postgresql.inst                       done
Running 40univention-virtual-machine-manager-schema.inst   done
Running 50univention-pkgdb.inst                            done
Running 65univention-ox.inst                               done
Running 67univention-mail-server.inst                      done
Running 81univention-ad-connector.inst                     done
Running 81univention-nfs-server.inst                       done
Running 82univention-mail-dovecot.inst                     done
Running 90univention-bind-post.inst                        done
Running 91univention-saml.inst                             done
Running 92univention-management-console-web-server.inst    done
Running 98univention-pkgdb-tools.inst                      done
Any hints in join.log?
I try to rejoin to get log
Fri Oct 26 15:14:35 +07 2018
RUNNING 10univention-ldap-server.inst
2018-10-26 15:14:35.723863770+07:00 (in joinscript_init)
Adding SRV record "ldap tcp 0 100 7389 email.domain.com." to zone domain.com...
done
Adding ZONE record "root@domain.com. 1 28800 10800 604800 108001 email.domain.com." to zone 10.0.200...
Adding SRV record "domaincontroller_master tcp 0 0 0 email.domain.com." to zone domain.com...
done
Object exists: cn=Univention,cn=packages,cn=univention,dc=domain,dc=com
Object exists: cn=Fernwartung,cn=packages,cn=univention,dc=domain,dc=com
Object exists: cn=Tools,cn=packages,cn=univention,dc=domain,dc=com
Object exists: cn=Multimedia,cn=packages,cn=univention,dc=domain,dc=com
Object exists: cn=Entwicklung,cn=packages,cn=univention,dc=domain,dc=com
LDAP Error: Type or value exists: modify/add: uniqueMember: value #0 already exists
__JOINERR__:FAILED: /usr/lib/univention-install/10univention-ldap-server.inst
EXITCODE=3
Fri Oct 26 15:15:06 +07 2018
cp: cannot stat '': No such file or directory
Fri Oct 26 15:16:29 +07 2018
RUNNING 26univention-samba.inst
2018-10-26 15:16:29.882328966+07:00 (in joinscript_init)
INFO: Cannot run joinscript in memberserver mode without join credentials. Please run:
to complete the domain join.
EXITCODE=2
Fri Oct 26 15:16:30 +07 2018
I try to run join scrip with other account(Admin permission) by
univention-run-join-scripts --ask-pass -dcaccount management --force --run-scripts 26univention-samba.inst
root@email:~# univention-run-join-scripts --ask-pass -dcaccount management --force --run-scripts 26uni                             vention-samba.inst
Search LDAP binddn ldap_sasl_bind(SIMPLE): Can't contact LDAP server (-1)
Insufficient access (50)
* Message:  binddn for user management not found
root@email:~# univention-run-join-scripts --ask-pass -dcaccount root --force --run-scripts 26univentio                             n-samba.inst
Search LDAP binddn Insufficient access (50)
* Message:  binddn for user root not found
root@email:~#
Now I can’t login into UMC again after reboot server, I can only login with Root user
I dunno what you are doing on your site. My posted command does not have any links to the administrator user account properties.
I have seen you where trying to use an account named “management” instead of administrator. It is very difficult to help when steps are mixed up.
So I have no clue what you are currently trying to do and which username you are using.
/CV
I just try another user to run join script because I try to run as Administrator user there is an error
What tells us::
univention-ldapsearch "uid=administrator"
