lun 5 feb 2018, 13.10.13, CET
RUNNING 01univention-ldap-server-init.inst
EXITCODE=already_executed
RUNNING 03univention-directory-listener.inst
RUNNING 04univention-ldap-client.inst
RUNNING 05univention-bind.inst
RUNNING 08univention-apache.inst
RUNNING 10univention-ldap-server.inst
RUNNING 11univention-heimdal-init.inst
RUNNING 11univention-pam.inst
RUNNING 15univention-heimdal-kdc.inst
RUNNING 18python-univention-directory-manager.inst
RUNNING 20univention-directory-policy.inst
RUNNING 20univention-join.inst
RUNNING 26univention-nagios-common.inst
RUNNING 30univention-appcenter.inst
RUNNING 30univention-nagios-client.inst
RUNNING 31univention-nagios-s4-connector.inst
RUNNING 31univention-nagios-samba.inst
RUNNING 33univention-portal.inst
RUNNING 34univention-management-console-server.inst
RUNNING 35univention-appcenter-docker.inst
RUNNING 35univention-management-console-module-appcenter.inst
RUNNING 35univention-management-console-module-diagnostic.inst
RUNNING 35univention-management-console-module-join.inst
RUNNING 35univention-management-console-module-lib.inst
RUNNING 35univention-management-console-module-mrtg.inst
RUNNING 35univention-management-console-module-quota.inst
RUNNING 35univention-management-console-module-reboot.inst
RUNNING 35univention-management-console-module-services.inst
RUNNING 35univention-management-console-module-setup.inst
RUNNING 35univention-management-console-module-sysinfo.inst
RUNNING 35univention-management-console-module-top.inst
RUNNING 35univention-management-console-module-ucr.inst
RUNNING 35univention-management-console-module-updater.inst
RUNNING 36univention-management-console-module-apps.inst
RUNNING 40univention-postgresql.inst
RUNNING 40univention-virtual-machine-manager-schema.inst
RUNNING 50nextcloud.inst
RUNNING 81univention-nfs-server.inst
RUNNING 90univention-bind-post.inst
RUNNING 92univention-management-console-web-server.inst
2018-02-05 13:10:26.161819459+01:00 (in joinscript_init)
05.02.18 13:10:28.830 DEBUG_INIT
UNIVENTION_DEBUG_BEGIN : uldap.__open host=ucs-8023.cdlmvenezia.intranet port=7389 base=dc=cdlmvenezia,dc=intranet
UNIVENTION_DEBUG_END : uldap.__open host=ucs-8023.cdlmvenezia.intranet port=7389 base=dc=cdlmvenezia,dc=intranet
Not updating samba4/role
Restarting univention-directory-listener (via systemctl): univention-directory-listener.service.
Multifile: /etc/samba/smb.conf
Object exists: cn=Builtin,dc=cdlmvenezia,dc=intranet
WARNING: cannot append cn=DC Backup Hosts,cn=groups,dc=cdlmvenezia,dc=intranet to nestedGroup, value exists
No modification: cn=Enterprise Domain Controllers,cn=groups,dc=cdlmvenezia,dc=intranet
WARNING: cannot append cn=ucs-7758,cn=dc,cn=computers,dc=cdlmvenezia,dc=intranet to hosts, value exists
Stopping samba-ad-dc (via systemctl): samba-ad-dc.service.
Stopping smbd (via systemctl): smbd.service.
Stopping nmbd (via systemctl): nmbd.service.
Setting kerberos/kdc
Setting kerberos/kpasswdserver
File: /etc/krb5.conf
Setting slapd/port
File: /etc/init.d/slapd
Setting slapd/port/ldaps
Restarting slapd (via systemctl): slapd.serviceWarning: Unit file of slapd.service changed on disk, ‘systemctl daemon-reload’ recommended.
Not updating windows/wins-support
Join against S4 Connector server: ucs-8023
Forest : cdlmvenezia.intranet
Domain : cdlmvenezia.intranet
Netbios domain : CDLMVENEZIA
DC name : ucs-8023.cdlmvenezia.intranet
DC netbios name : UCS-8023
Server site : Default-First-Site-Name
Client site : Default-First-Site-Name
workgroup is CDLMVENEZIA
realm is cdlmvenezia.intranet
ERROR(ldb): uncaught exception - LDAP error 68 LDAP_ENTRY_ALREADY_EXISTS - <00002071: …/ldb_tdb/ldb_index.c:1238: Failed to re-index objectSid in CN=UCS-7758,OU=Domain Controllers,DC=cdlmvenezia,DC=intranet - …/ldb_tdb/ldb_index.c:1158: unique index violation on objectSid in CN=UCS-7758,OU=Domain Controllers,DC=cdlmvenezia,DC=intranet> <>
File “/usr/lib/python2.7/dist-packages/samba/netcmd/init.py”, line 176, in _run
return self.run(*args, **kwargs)
File “/usr/lib/python2.7/dist-packages/samba/netcmd/domain.py”, line 668, in run
keep_existing=keep_existing)
File “/usr/lib/python2.7/dist-packages/samba/join.py”, line 1276, in join_DC
ctx.do_join()
File “/usr/lib/python2.7/dist-packages/samba/join.py”, line 1182, in do_join
ctx.join_add_objects()
File “/usr/lib/python2.7/dist-packages/samba/join.py”, line 593, in join_add_objects
ctx.samdb.add(rec)
Adding CN=UCS-7758,OU=Domain Controllers,DC=cdlmvenezia,DC=intranet
Join failed - cleaning up
Failed to join against the S4 Connector server ucs-8023.
Finding a writeable DC for domain ‘cdlmvenezia.intranet’
Found DC ucs-8023.cdlmvenezia.intranet
ctx.do_join()
ctx.samdb.add(rec)
Failed to join the domain cdlmvenezia.intranet.
EXITCODE=1
RUNNING 97univention-s4-connector.inst
2018-02-05 13:11:35.327046429+01:00 (in joinscript_init)
Samba4 backend database not available yet, exiting joinscript 98univention-samba4-dns.
EXITCODE=1
