here the join.log
2023-08-13 23:55:40.994201997+02:00 (in joinscript_save_current_version)
EXITCODE=0
RUNNING 92univention-fetchmail-schema.inst
2023-08-13 23:55:41.054027063+02:00 (in joinscript_init)
Object exists: cn=ldapschema,cn=univention,dc=virea,dc=intranet
Object exists: cn=ldapacl,cn=univention,dc=virea,dc=intranet
INFO: No change of core data of object univention-fetchmail.
INFO: No change of core data of object 58univention-fetchmail-schema.
No modification: cn=univention-fetchmail,cn=ldapschema,cn=univention,dc=virea,dc=intranet
No modification: cn=58univention-fetchmail-schema,cn=ldapacl,cn=univention,dc=virea,dc=intranet
Waiting for activation of the extension object univention-fetchmail: OK
Waiting for activation of the extension object 58univention-fetchmail-schema: OK
Object exists: cn=udm_syntax,cn=univention,dc=virea,dc=intranet
INFO: No change of core data of object fetchmail.
Object modified: cn=fetchmail,cn=udm_syntax,cn=univention,dc=virea,dc=intranet
Waiting for activation of the extension object fetchmail: OK
Waiting for file /usr/lib/python3/dist-packages/univention/admin/syntax.d/fetchmail.py: OK
Object exists: cn=udm_hook,cn=univention,dc=virea,dc=intranet
No modification: cn=fetchmail,cn=udm_hook,cn=univention,dc=virea,dc=intranet
Waiting for file /usr/lib/python3/dist-packages/univention/admin/hooks.d/fetchmail.py: OK
Object exists: cn=mail,cn=custom attributes,cn=univention,dc=virea,dc=intranet
Object exists: cn=FetchmailConfigSingle,cn=mail,cn=custom attributes,cn=univention,dc=virea,dc=intranet
Create extended attribute univentionFetchmailSingle univentionFetchmailMulti
Object exists: cn=FetchmailConfigMulti,cn=mail,cn=custom attributes,cn=univention,dc=virea,dc=intranet
2023-08-13 23:55:48.836814491+02:00 (in joinscript_save_current_version)
EXITCODE=0
RUNNING 92univention-management-console-web-server.inst
2023-08-13 23:55:49.081109571+02:00 (in joinscript_init)
W: The config registry variable ‘ucs/web/overview/entries/admin/umc/icon’ does not exist
W: The config registry variable ‘ucs/web/overview/entries/admin/umc/link’ does not exist
W: The config registry variable ‘ucs/web/overview/entries/admin/umc/link/de’ does not exist
W: The config registry variable ‘ucs/web/overview/entries/admin/umc/priority’ does not exist
W: The config registry variable ‘ucs/web/overview/entries/admin/umc/label’ does not exist
W: The config registry variable ‘ucs/web/overview/entries/admin/umc/label/de’ does not exist
W: The config registry variable ‘ucs/web/overview/entries/admin/umc/description’ does not exist
W: The config registry variable ‘ucs/web/overview/entries/admin/umc/description/de’ does not exist
Object exists: SAMLServiceProviderIdentifier=https://ucs-Mail.virea.intranet/univention/saml/metadata,cn=saml-serviceprovider,cn=univention,dc=virea,dc=intranet
Object modified: SAMLServiceProviderIdentifier=https://ucs-Mail.virea.intranet/univention/saml/metadata,cn=saml-serviceprovider,cn=univention,dc=virea,dc=intranet
Not updating ucs/server/sso/fqdn
rm: das Entfernen von ‘/usr/share/univention-management-console/saml/idp/*.xml’ ist nicht möglich: Datei oder Verzeichnis nicht gefunden
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
curl: (22) The requested URL returned error: 404 Not Found
E: your request could not be fulfilled
try univention-config-registry --help for more information
Create umc/saml/idp-server
Module: setup_saml_sp
Try to download idp metadata (1/60)
Try to download idp metadata (2/60)
Try to download idp metadata (3/60)
Try to download idp metadata (4/60)
Try to download idp metadata (5/60)
Try to download idp metadata (6/60)
Try to download idp metadata (7/60)
Try to download idp metadata (8/60)
Try to download idp metadata (9/60)
Try to download idp metadata (10/60)
Try to download idp metadata (11/60)
Try to download idp metadata (12/60)
Try to download idp metadata (13/60)
Try to download idp metadata (14/60)
Try to download idp metadata (15/60)
Try to download idp metadata (16/60)
Try to download idp metadata (17/60)
Try to download idp metadata (18/60)
Try to download idp metadata (19/60)
Try to download idp metadata (20/60)
Try to download idp metadata (21/60)
Try to download idp metadata (22/60)
Try to download idp metadata (23/60)
Try to download idp metadata (24/60)
Try to download idp metadata (25/60)
Try to download idp metadata (26/60)
Try to download idp metadata (27/60)
Try to download idp metadata (28/60)
Try to download idp metadata (29/60)
Try to download idp metadata (30/60)
Try to download idp metadata (31/60)
Try to download idp metadata (32/60)
Try to download idp metadata (33/60)
Try to download idp metadata (34/60)
Try to download idp metadata (35/60)
Try to download idp metadata (36/60)
Try to download idp metadata (37/60)
Try to download idp metadata (38/60)
Try to download idp metadata (39/60)
Try to download idp metadata (40/60)
Try to download idp metadata (41/60)
Try to download idp metadata (42/60)
Try to download idp metadata (43/60)
Try to download idp metadata (44/60)
Try to download idp metadata (45/60)
Try to download idp metadata (46/60)
Try to download idp metadata (47/60)
Try to download idp metadata (48/60)
Try to download idp metadata (49/60)
Try to download idp metadata (50/60)
Try to download idp metadata (51/60)
Try to download idp metadata (52/60)
Try to download idp metadata (53/60)
Try to download idp metadata (54/60)
Try to download idp metadata (55/60)
Try to download idp metadata (56/60)
Try to download idp metadata (57/60)
Try to download idp metadata (58/60)
Try to download idp metadata (59/60)
Try to download idp metadata (60/60)
Unsetting umc/saml/idp-server
Module: kopano-cfg
umc/saml/idp-server not set, nothing to do
EXITCODE=3
660f3933-3eb3-4669-b494-d837e9303fbd
2023-08-13 23:56:53.960596912+02:00 (in joinscript_init)
Cannot find service-record of _pkgdb._tcp.
No DB-Server-Name found.
2023-08-13 23:56:54.120561541+02:00 (in joinscript_save_current_version)
EXITCODE=0
RUNNING 99kopano4ucs-safemode-off.inst
2023-08-13 23:56:54.151216419+02:00 (in joinscript_init)
Setting kopano/cfg/server/user_safe_mode
Module: kopano-cfg
Unsetting kopano/cfg/server/user_safe_mode
Module: kopano-cfg
Waiting for kopano-server startup
2023-08-13 23:56:54.580294530+02:00 (in joinscript_save_current_version)
EXITCODE=0
univention-join-hooks: looking for hook type “join/post-joinscripts” on ucs01.virea.intranet
Found hooks:
So 13. Aug 23:56:55 CEST 2023
