(I posted this here before, but was asked to move it to an own topic, because of the different underlying conditions.)
We have a similar problem. Sorry if this is the wrong place for our problem, but maybe the problems are related. Our domain consists of four UCS systems:
- ucs-master
- ucs-slave
- ucs-backup
- ucs-ext
All of them are showing
Die folgenden KDCs waren nicht erreichbar: tcp ucs-*.foo.bar:88
So ucs-master show ucs-master.foo.bar:88
, ucs-slave ucs-slave.foo.bar:88
and so on.
host -t srv _kerberos._tcp.$(ucr get domainname)
shows all of them on all systems.
kinit --password-file=/etc/machine.secret $(hostname)\$@$(ucr get kerberos/realm)
seems to work on all systems, at least klist
shows issued tickets afterwards.
echo -ne "server $(ucr get ldap/master)\nprereq yxdomain $(hostname -f)\nsend\n" | nsupdate -d -g -t15
also looks like it works correctly.
When I run tcpdump -i eth0 tcp port 88
and run system diagnostics again, it shows connections to all systems except the one where I’m running it, for which it reports KDC unreachable. When I run tcpdump -i lo tcp port 88
it shows connections to localhost. Any idea?
Edit: I just solved my problem by adding ucs-slave ucs-slave.foo.bar
to the /etc/hosts using:
ucr set hosts/static/127.0.0.1="localhost ucs-slave ucs-slave.foo.bar"
My /etc/hosts
before the change:
127.0.0.1 localhost
192.168.1.2 ucs-slave.foo.bar ucs-slave
127.0.1.1 ucs-slave.foo.bar ucs-slave
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
I don’t fully understand why it works now, though.
Hey,
even though you’ve found a workaround, can you please show the output of lsof -PniTCP:88
from both ucs-slave
and ucs-master
Kind regards,
mosu
ucs-master
samba 23392 root 24u IPv6 2290188 0t0 TCP [::1]:88 (LISTEN)
samba 23392 root 34u IPv4 2290192 0t0 TCP 127.0.0.1:88 (LISTEN)
samba 23392 root 38u IPv4 2290196 0t0 TCP 192.168.1.1:88 (LISTEN)
ucs-slave
samba 1263 root 24u IPv6 18348 0t0 TCP [::1]:88 (LISTEN)
samba 1263 root 34u IPv4 18352 0t0 TCP 127.0.0.1:88 (LISTEN)
samba 1263 root 38u IPv4 18356 0t0 TCP 192.168.1.2:88 (LISTEN)
Hey,
This seems wrong to me. I know other systems such as Ubuntu or Debian tend to set up 127.0.1.1 with the desired host name, but on UCS systems this is usually not the case. I’ve just verified with three different systems (one a newly set-up 4.2, the others long-lived systems originally set up in the 3.0 days and upgrade since), and neither of them contains such an entry.
What UCR variables have you set for static entries (see ucr search --brief hosts/static
on both systems)?
Kind regards,
mosu
ucs-master:~# ucr search --brief hosts/static
hosts/static/.*: <empty>
hosts/static/127.0.0.1: localhost ucs-master ucs-master.foo.bar
hosts/static/127.0.1.1: ucs-master.foo.bar ucs-master
ucs-slave:~# ucr search --brief hosts/static
hosts/static/127.0.0.1: localhost ucs-slave ucs-slave.foo.bar
hosts/static/127.0.1.1: ucs-slave.foo.bar ucs-slave
I don’t remember setting 127.0.1.1, but I have two other UCS systems not affected by the problem, that have hosts/static/127.0.1.1 set.
Hey,
I still suggest you remove both entries (hosts/static/127.0.0.1
and hosts/static/127.0.1.1
), reboot the server and run the system diagnostics again. One of the reasons is that having DNS consistent across the whole UCS domain is an important basis for it working well. That includes that host names resolve identically no matter on which host you query it on (e.g. ucs-slave.foo.bar
should always resolve to 192.168.1.2, no matter if you’re currently on ucs-master
or on ucs-slave
itself) and which method is used (contacting a DNS server directly or using glibc
's stub resolver via functions such as gethostbyname
Kind regards,
mosu
Thanks, I removed both entries on all systems and rebooted them. System diagnostics still does not report any problem.
On the other domain there is an ucs-master and an ucs-backup.
root@ucs-master:~# cat /etc/hosts
127.0.0.1 localhost
192.168.100.1 ucs-master.bar.foo ucs-master
127.0.0.1 localhost localhost_sync
127.0.1.1 ucs-master.bar.foo ucs-master
localhost_sync
seems to have something to do with Open XChange according to Google. Should I also remove both entries here?
Hey,
why is there still an entry for 127.0.1.1 on your ucs-master
if the entries have UCR variables have really been unset? That doesn’t really make sense… Please post the output of grep -Fr 127.0.1.1 /etc
; it should give us some clues.
I need to mention that my OX test installation does contain static host entries for 127.0.1.1
, too. I haven’t found out where and when they’re set, though; neither the package installation files in /var/lib/dpkg/info
nor the domain join scripts in /usr/lib/univention-install
do anything with 127.0.1.1
… Very strange.
What’s even stranger is that I can reproduce the “KDC not reachable” issue on that machine as well. Removing the 127.0.1.1
entry doesn’t solve the issue for me. I’ll have to look into this some more.
Kind regards,
mosu
Hi mosu,
why is there still an entry for 127.0.1.1 on your ucs-master if the entries have UCR variables have really been unset? That doesn’t really make sense…
My previous post was about a totally different domain. Sorry for not making it clear enough.
I do not have the “KDC not reachable” issue on this other domain.
Edit: Suddenly I have the same problem in the other domain…
Maybe this is the same false positive/bug in the check that Stefan Gomann mentioned in this post:
KDC check fails due to “Record Mark” option in network package
