When i try to install zarafa from app center i get the the following message: zarafa 4ucs: No such package
I downloaded UCS 3.1 two days ago and are using a community UCS server.
Thanks
Thanks
could you please attach the output of the following command (executed as user root on commandline):
ucr search --brief repository
Kind regards,
Tim Petersen
Hello Thanks for reaction:
local/repository: <empty>
online/repository/clean: <empty>
repository/mirror/architectures: <empty>
repository/mirror/basepath: /var/lib/univention-repository
repository/mirror/httpmethod: <empty>
repository/mirror/port: <empty>
repository/mirror/prefix: <empty>
repository/mirror/recreate_packages: yes
repository/mirror/server: <empty>
repository/mirror/sources: <empty>
repository/mirror/threads: 10
repository/mirror/version/end: <empty>
repository/mirror/version/start: <empty>
repository/mirror: false
repository/online/architectures: <empty>
repository/online/component/3.1-0-errata/description: Errata updates for UCS 3.1-0
repository/online/component/3.1-0-errata/version: 3.1
repository/online/component/3.1-0-errata: enabled
repository/online/component/zarafa_20130125-errata/description: Zarafa Collaboration Platform Errata
repository/online/component/zarafa_20130125-errata/localmirror: false
repository/online/component/zarafa_20130125-errata/parts: maintained
repository/online/component/zarafa_20130125-errata/server: appcenter.software-univention.de
repository/online/component/zarafa_20130125-errata/version: current
repository/online/component/zarafa_20130125-errata: enabled
repository/online/component/zarafa_20130125/description: Zarafa is a complete replacement for Microsoft Exchange under Linux.
repository/online/component/zarafa_20130125/localmirror: false
repository/online/component/zarafa_20130125/parts: maintained
repository/online/component/zarafa_20130125/server: appcenter.software-univention.de
repository/online/component/zarafa_20130125/version: current
repository/online/component/zarafa_20130125: enabled
repository/online/errata/start: <empty>
repository/online/hotfixes: no
repository/online/httpmethod: <empty>
repository/online/maintained: yes
repository/online/port: 80
repository/online/prefix: <empty>
repository/online/server: univention-repository.mgba.eu
repository/online/sources: <empty>
repository/online/unmaintained: no
repository/online: yes
the repository settings are a bit misconfigured. I would like to have a more detailed look on your system to be sure about the next steps. Could you please provide us an univention-support-info archive as described at sdb article #1182?
You can either send the archive to feedback@univention.de with a short description, or use upload.univention.de as described in the article for uploading. In this case, please provide us the generated archive name here after uploading.
Kind regards,
Tim Petersen
I decided yesterday to reinstall it again and now it works, i will give you my roadmap:
Thanks for your time and help.
Hello Found out what was wrong seems that after a new install repository server was like: updates.software-domain.eu. This should be updates.software-univention.de. After i changed it every thing works well.
You’re right, and nice to hear that it is working now - I would like to take a look at your other settings in order to be able to track this down - could you please provide us an univention-support-info archive as described in sdb article #1182?
Kind regards,
Tim Petersen
