I previously had a windows domain but wanted to try something else. I have a lot of other services that run on the network with a reverse proxy host to proxy them all. When setting up the domain, I set it to “ad.gokurocks.com”. That resolves fine. Any device I add also resolves to an IP. “shenron.ad.gokurocks.com” for instance. All the services on the network are formatted like “ha.gokurocks.com”, “pdfeditor.gokurocks.com”, etc. In the past, I just setup a wildcard “*.gokurocks.com” and everything worked fine. How do I do that with UCS? Is it possible?
