Hi, Is it possible to build a simple web interface to add users only with 10/15 groups (not ALL) and only in a specific OU? In same interface I want to permit to lock only specific OU users too
Can you help me about?
Thank you
Thank you
Hi Uzzi,
your question is not very specific. But the answer is most probably yes
Maybe the UMC user module is helpful for you?
https://docs.software-univention.de/manual-5.0.html#users::management
Thank toy @friedrich , I need a simple web interface to write a users details only restricted for particular user an groups. For example:
User A can be write/modify details only for specific OU users or add user on same OU
User B can be write/modify details only for other OU users or add user on same OU
Hi @Uzzi,
Your usecase depends on the product flavour, if you have UCS@School, then permissions are already set per school.
Please read the manual about policies and groups, I’m sure you’ll find your solution there:
https://docs.software-univention.de/manual-5.0.html#central:policies
