Hallo
Hier mal was dmesg augibt, gefiltert mach usb,ohci, ehci, xhci …
[ 1.816707] usbcore: registered new interface driver usbfs
[ 1.816717] usbcore: registered new interface driver hub
[ 1.817024] usbcore: registered new device driver usb
[ 1.819958] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.821048] ehci-pci: EHCI PCI platform driver
[ 1.821198] ehci-pci 0000:00:12.2: EHCI Host Controller
[ 1.821203] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 1.821207] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.821218] ehci-pci 0000:00:12.2: debug port 1
[ 1.821257] ehci-pci 0000:00:12.2: irq 17, io mem 0xfe909000
[ 1.825342] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.833994] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 1.834085] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.834087] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.834088] usb usb1: Product: EHCI Host Controller
[ 1.834089] usb usb1: Manufacturer: Linux 4.9.0-ucs104-amd64 ehci_hcd
[ 1.834089] usb usb1: SerialNumber: 0000:00:12.2
[ 1.834530] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 1.834539] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 2
[ 1.893525] xhci_hcd 0000:03:00.0: hcc params 0x0200eec1 hci version 0x110 quirks 0x00000010
[ 1.893747] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.893748] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.893749] usb usb2: Product: xHCI Host Controller
[ 1.893750] usb usb2: Manufacturer: Linux 4.9.0-ucs104-amd64 xhci-hcd
[ 1.893750] usb usb2: SerialNumber: 0000:03:00.0
[ 1.893967] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 1.893971] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 3
[ 1.893976] ehci-pci 0000:00:13.2: EHCI Host Controller
[ 1.894019] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 4
[ 1.894022] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.894036] ehci-pci 0000:00:13.2: debug port 1
[ 1.894056] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.894081] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.894082] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.894083] usb usb3: Product: xHCI Host Controller
[ 1.894084] usb usb3: Manufacturer: Linux 4.9.0-ucs104-amd64 xhci-hcd
[ 1.894085] usb usb3: SerialNumber: 0000:03:00.0
[ 1.894110] ehci-pci 0000:00:13.2: irq 17, io mem 0xfe907000
[ 1.910071] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.910238] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.910239] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.910240] usb usb4: Product: EHCI Host Controller
[ 1.910241] usb usb4: Manufacturer: Linux 4.9.0-ucs104-amd64 ehci_hcd
[ 1.910242] usb usb4: SerialNumber: 0000:00:13.2
[ 1.910579] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 1.910585] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 5
[ 1.910686] xhci_hcd 0000:06:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00000090
[ 1.910767] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.910768] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.910769] usb usb5: Product: xHCI Host Controller
[ 1.910770] usb usb5: Manufacturer: Linux 4.9.0-ucs104-amd64 xhci-hcd
[ 1.910771] usb usb5: SerialNumber: 0000:06:00.0
[ 1.910953] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 1.910955] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 6
[ 1.910971] ehci-pci 0000:00:16.2: EHCI Host Controller
[ 1.910972] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.910990] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.910991] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.910992] usb usb6: Product: xHCI Host Controller
[ 1.910993] usb usb6: Manufacturer: Linux 4.9.0-ucs104-amd64 xhci-hcd
[ 1.910994] usb usb6: SerialNumber: 0000:06:00.0
[ 1.911218] ehci-pci 0000:00:16.2: new USB bus registered, assigned bus number 7
[ 1.911220] ehci-pci 0000:00:16.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.911227] ehci-pci 0000:00:16.2: debug port 1
[ 1.911277] ehci-pci 0000:00:16.2: irq 17, io mem 0xfe904000
[ 1.926076] ehci-pci 0000:00:16.2: USB 2.0 started, EHCI 1.00
[ 1.926248] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.926250] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.926251] usb usb7: Product: EHCI Host Controller
[ 1.926252] usb usb7: Manufacturer: Linux 4.9.0-ucs104-amd64 ehci_hcd
[ 1.926253] usb usb7: SerialNumber: 0000:00:16.2
[ 1.927805] ohci-pci: OHCI PCI platform driver
[ 1.928530] ohci-pci 0000:00:12.0: OHCI PCI host controller
[ 1.928536] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 8
[ 1.928563] ohci-pci 0000:00:12.0: irq 18, io mem 0xfe90a000
[ 1.990103] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.990105] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.990106] usb usb8: Product: OHCI PCI host controller
[ 1.990107] usb usb8: Manufacturer: Linux 4.9.0-ucs104-amd64 ohci_hcd
[ 1.990108] usb usb8: SerialNumber: 0000:00:12.0
[ 1.990462] ohci-pci 0000:00:13.0: OHCI PCI host controller
[ 1.990466] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 9
[ 1.990480] ohci-pci 0000:00:13.0: irq 18, io mem 0xfe908000
[ 2.054106] usb usb9: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.054108] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.054109] usb usb9: Product: OHCI PCI host controller
[ 2.054110] usb usb9: Manufacturer: Linux 4.9.0-ucs104-amd64 ohci_hcd
[ 2.054110] usb usb9: SerialNumber: 0000:00:13.0
[ 2.054440] ohci-pci 0000:00:14.5: OHCI PCI host controller
[ 2.054443] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 10
[ 2.054462] ohci-pci 0000:00:14.5: irq 18, io mem 0xfe906000
[ 2.118103] usb usb10: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.118105] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.118106] usb usb10: Product: OHCI PCI host controller
[ 2.118107] usb usb10: Manufacturer: Linux 4.9.0-ucs104-amd64 ohci_hcd
[ 2.118108] usb usb10: SerialNumber: 0000:00:14.5
[ 2.118405] ohci-pci 0000:00:16.0: OHCI PCI host controller
[ 2.118409] ohci-pci 0000:00:16.0: new USB bus registered, assigned bus number 11
[ 2.118424] ohci-pci 0000:00:16.0: irq 18, io mem 0xfe905000
[ 2.182103] usb usb11: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.182105] usb usb11: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.182106] usb usb11: Product: OHCI PCI host controller
[ 2.182107] usb usb11: Manufacturer: Linux 4.9.0-ucs104-amd64 ohci_hcd
[ 2.182108] usb usb11: SerialNumber: 0000:00:16.0
[ 2.246021] usb 5-1: new high-speed USB device number 2 using xhci_hcd
[ 2.282084] usb 2-1: new full-speed USB device number 2 using xhci_hcd
[ 2.387901] usb 5-1: New USB device found, idVendor=2109, idProduct=3431
[ 2.387903] usb 5-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.387904] usb 5-1: Product: USB2.0 Hub
[ 2.665625] usb 2-1: New USB device found, idVendor=051d, idProduct=0002
[ 2.665630] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.665632] usb 2-1: Product: Back-UPS RS 1200G FW:877.L5 .I USB FW:L5
[ 2.665635] usb 2-1: Manufacturer: American Power Conversion
[ 2.665637] usb 2-1: SerialNumber: 3B1729X03748
[ 2.690037] usb 5-1.1: new low-speed USB device number 3 using xhci_hcd
[ 2.697628] usbcore: registered new interface driver usbhid
[ 2.697628] usbhid: USB HID core driver
[ 2.802846] usb 5-1.1: New USB device found, idVendor=045e, idProduct=07f8
[ 2.802848] usb 5-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.802849] usb 5-1.1: Product: Wired Keyboard 600
[ 2.802850] usb 5-1.1: Manufacturer: Microsoft
[ 2.810918] input: Microsoft Wired Keyboard 600 as /devices/pci0000:00/0000:00:15.1/0000:06:00.0/usb5/5-1/5-1.1/5-1.1:1.0/0003:045E:07F8.0002/input/input5
[ 2.870326] hid-generic 0003:045E:07F8.0002: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Wired Keyboard 600] on usb-0000:06:00.0-1.1/input0
[ 2.877908] input: Microsoft Wired Keyboard 600 as /devices/pci0000:00/0000:00:15.1/0000:06:00.0/usb5/5-1/5-1.1/5-1.1:1.1/0003:045E:07F8.0003/input/input6
[ 2.920601] hid-generic 0003:051D:0002.0001: hiddev0,hidraw1: USB HID v1.00 Device [American Power Conversion Back-UPS RS 1200G FW:877.L5 .I USB FW:L5 ] on usb-0000:03:00.0-1/input0
[ 2.934231] hid-generic 0003:045E:07F8.0003: input,hidraw2: USB HID v1.11 Device [Microsoft Wired Keyboard 600] on usb-0000:06:00.0-1.1/input1
[ 3.018125] usb 5-1.2: new low-speed USB device number 4 using xhci_hcd
[ 3.125765] usb 5-1.2: New USB device found, idVendor=ffc0, idProduct=0040
[ 3.125767] usb 5-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.125768] usb 5-1.2: Product: USB Laser Mouse
[ 3.125768] usb 5-1.2: Manufacturer: Mouse
[ 3.131771] input: Mouse USB Laser Mouse as /devices/pci0000:00/0000:00:15.1/0000:06:00.0/usb5/5-1/5-1.2/5-1.2:1.0/0003:FFC0:0040.0004/input/input7
[ 3.131939] hid-generic 0003:FFC0:0040.0004: input,hidraw3: USB HID v1.11 Mouse [Mouse USB Laser Mouse] on usb-0000:06:00.0-1.2/input0
[130771.296530] xhci_hcd 0000:06:00.0: Cannot set link state.
[130771.296545] usb usb6-port4: cannot disable (err = -32)
[130771.296558] usb 6-4: USB disconnect, device number 2
[50640.842068] usb 6-4: new SuperSpeed USB device number 2 using xhci_hcd
[50640.864543] usb 6-4: New USB device found, idVendor=05dc, idProduct=b051
[50640.864547] usb 6-4: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[50640.864550] usb 6-4: Product: microSD RDR
[50640.864552] usb 6-4: Manufacturer: Lexar
[50640.864554] usb 6-4: SerialNumber: 1
[50640.875995] usb-storage 6-4:1.0: USB Mass Storage device detected
[50640.876219] scsi host6: usb-storage 6-4:1.0
[50640.876419] usbcore: registered new interface driver usb-storage
[50640.880905] usbcore: registered new interface driver uas
und vielleicht auch was lsusb zeigt :
Bus 011 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 010 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 004: ID ffc0:0040
Bus 005 Device 003: ID 045e:07f8 Microsoft Corp.
Bus 005 Device 002: ID 2109:3431
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Maus und Tatstatur hängen an USB3 das UPS an USB3.1
