URLs with or without a trailing slash are treated differently
apache
http
web
#1
Kudos at @Moritz_Bunkus
Question
For some apps it is a difference if they get called by https://ucs.domain.com/app or https://ucs.domain.com/app/. How can I get both URLs available?
Answer
Add a file to Apache, e.g. /etc/apache2/conf-available/app-fix.conf , with the following content:
RedirectMatch ^/app$ /app/
Enable the configuration:
a2enconf app-fix
systemctl reload apache2
Then both URLs can be used similarly.
#2
