Upgrade UCS 4.2. to 4.4
I have an UCS core installation (Master + Backup) which is still on UCS 4.2.3
Is it possible to directly upgrade to 4.4 (latest) or should i go step by step eg 4.2.3 - 4.2.4 - 4.2.5 - 4.3.0 … ?
thanks for input
rg
Christian
Hey,
direct updates are neither supported nor implemented. You must follow all the intermediate versions.
In the past there have been instances where you could skip a minor release (e.g. you could upgrade from 3.3-3 to 4.0-0 without going to 3.3-4 first if I remember correctly), but that was an exception.
