Upgrade to UCS 4.4.4 does not finsh
i want to upgrade my UCS Server 4.3.2 to the latest version. I cant see any error in de var/log/univention/update.log. but it is updating since 15 hours. I checked other logs as well but i cant find suspicious entrys or i missed them.
What can i do?
To explain the context:
The plan is to replace the master domain controller with new hardware. I installed on a new server the same UCS Version 4.3.2 as the old DC Master and joined the domain as DC Backup. I put the DC backup server in test environment , promoted the DC backup to DC master. everything was worked well. and now i try to upgrade this new server to the latest UCS version.
Thanks for any advice.
Ric
var/log/univention/update.log:
Starting univention-upgrade. Current UCS version is 4.3-2 errata229
Checking for package updates: found
Please rerun command without --check argument to install.
The following packages will be installed:
sysvinit,python-cached-property,python-websocket,python-backports.ssl-match-hostname,python-docker,python-dockerpty,python-docopt,python-functools32,python-funcsigs,python-pbr,python-mock,python3-pkg-resources,python-jsonschema,python-texttable,docker-compose,python-ruamel.ordereddict,python-typing,python-ruamel.yaml,python-lazy-object-proxy,hunspell-de-de
The following packages will be upgraded:
base-files,libperl5.24,perl,perl-base,perl-modules-5.24,xserver-common,xserver-xorg-core,libudev1,udev,libpam-systemd,libsystemd0,systemd,systemd-sysv,libseccomp2,libprocps3,libssl1.0.2,apache2,apache2-bin,apache2-utils,apache2-data,grub-pc,grub-pc-bin,grub2-common,libfuse2,grub-common,imagemagick-6-common,liblcms2-2,libtiff5,libx11-data,libx11-6,libmagickcore-6.q16-3,libmagickwand-6.q16-3,samba-vfs-modules,python2.7,python2.7-minimal,libpython2.7,libpython2.7-stdlib,libpython2.7-minimal,libssl1.1,python-samba,samba,samba-dsdb-modules,winbind,smbclient,libsmbclient,samba-common-bin,samba-libs,libwbclient0,samba-common,libarchive13,libunbound2,libgnutls-dane0,libgnutls30,libvlccore9,libvlc5,python3.5,python3.5-minimal,libpython3.5-stdlib,libpython3.5-minimal,qemu-system-common,openssl,stunnel4,univention-config,python-univention-config-registry,univention-appcenter-docker,univention-web-js,univention-web-style,univention-management-console-login,univention-management-console-frontend,univention-base-packages,shell-univention-lib,python-univention-lib,univention-base-files,curl,libcurl3,php7.0-json,php7.0-opcache,tzdata,php7.0-cgi,php7.0-ldap,php7.0-mcrypt,php7.0-xml,php7.0-readline,libapache2-mod-php7.0,php7.0-cli,php7.0-common,univention-directory-manager-tools,python-univention-directory-manager,python-univention-directory-manager-cli,apache2-suexec-pristine,univention-saml,univention-saml-schema,univention-management-console-web-server,univention-management-console-module-updater,univention-errata-level,univention-updater,univention-management-console-module-join,univention-join,univention-management-console,univention-management-console-server,python-univention-management-console,univention-management-console-module-setup,univention-system-setup,univention-management-console-module-apps,univention-management-console-module-appcenter,univention-management-console-module-diagnostic,libunivention-config0,libunivention-policy0,univention-directory-listener,univention-portal,dirmngr,gnupg,gnupg-agent,univention-appcenter,python-univention-appcenter,univention-ssl,univention-ldap-acl-master,univention-ldap-server,univention-ldap-config,univention-policy-tools,univention-quota,vlc-plugin-video-output,libbasicusageenvironment1,libgroupsock8,liblivemedia57,libopenmpt0,libopenmpt-modplug1,libusageenvironment3,vlc-plugin-base,vlc-data,gpgv,libxapian30,libtirpc1,dnsmasq-base,firefox-esr-l10n-de,libx11-xcb1,firefox-esr,firmware-amd-graphics,firmware-linux,firmware-linux-nonfree,firmware-misc-nonfree,firmware-atheros,firmware-bnx2,firmware-bnx2x,firmware-brcm80211,firmware-cavium,firmware-intelwimax,firmware-iwlwifi,firmware-libertas,firmware-myricom,firmware-netxen,firmware-qlogic,firmware-realtek,firmware-ti-connectivity,ghostscript,libgs9,libgs9-common,gnutls-bin,libcurl3-gnutls,libgd3,libmariadbclient18,okular,libokularcore7,policykit-1,libpolkit-agent-1-0,libpolkit-backend-1-0,libpolkit-gobject-1-0,librbd1,librados2,libspice-server1,libssh-gcrypt-4,libxcursor1,linux-image-4.9.0-8-amd64-signed,linux-image-4.9.0-8-amd64,mariadb-common,mariadb-client-core-10.1,mariadb-server-core-10.1,php7.0,univention-samba-local-config,univention-samba4,univention-samba4-sysvol-sync,univention-s4-connector,python-univention-connector-s4,univention-virtual-machine-manager-schema,python-univention-directory-manager-uvmm,univention-virtual-machine-manager-daemon,univention-management-console-module-uvmm,python-univention-virtual-machine-manager,qemu-kvm,libbrlapi0.6,qemu-system-x86,qemu-utils,univention-ldap-client,univention-management-console-module-quota,univention-management-console-module-udm,univention-radius
Starting dist-update at Thu Apr 30 09:18:41 2020…
Starting package upgrade Paketlisten werden gelesen…
Abhängigkeitsbaum wird aufgebaut…
Statusinformationen werden eingelesen…
Paketaktualisierung (Upgrade) wird berechnet…
Die folgenden NEUEN Pakete werden installiert:
docker-compose hunspell-de-de python-backports.ssl-match-hostname
python-cached-property python-docker python-dockerpty python-docopt
python-funcsigs python-functools32 python-jsonschema
python-lazy-object-proxy python-mock python-pbr python-ruamel.ordereddict
python-ruamel.yaml python-texttable python-typing python-websocket
python3-pkg-resources sysvinit
Die folgenden Pakete werden aktualisiert (Upgrade):
apache2 apache2-bin apache2-data apache2-suexec-pristine apache2-utils
base-files curl dirmngr dnsmasq-base firefox-esr firefox-esr-l10n-de
firmware-amd-graphics firmware-atheros firmware-bnx2 firmware-bnx2x
firmware-brcm80211 firmware-cavium firmware-intelwimax firmware-iwlwifi
firmware-libertas firmware-linux firmware-linux-nonfree
firmware-misc-nonfree firmware-myricom firmware-netxen firmware-qlogic
firmware-realtek firmware-ti-connectivity ghostscript gnupg gnupg-agent
gnutls-bin gpgv grub-common grub-pc grub-pc-bin grub2-common
imagemagick-6-common libapache2-mod-php7.0 libarchive13
libbasicusageenvironment1 libbrlapi0.6 libcurl3 libcurl3-gnutls libfuse2
libgd3 libgnutls-dane0 libgnutls30 libgroupsock8 libgs9 libgs9-common
liblcms2-2 liblivemedia57 libmagickcore-6.q16-3 libmagickwand-6.q16-3
libmariadbclient18 libokularcore7 libopenmpt-modplug1 libopenmpt0
libpam-systemd libperl5.24 libpolkit-agent-1-0 libpolkit-backend-1-0
libpolkit-gobject-1-0 libprocps3 libpython2.7 libpython2.7-minimal
libpython2.7-stdlib libpython3.5-minimal libpython3.5-stdlib librados2
librbd1 libseccomp2 libsmbclient libspice-server1 libssh-gcrypt-4
libssl1.0.2 libssl1.1 libsystemd0 libtiff5 libtirpc1 libudev1 libunbound2
libunivention-config0 libunivention-policy0 libusageenvironment3 libvlc5
libvlccore9 libwbclient0 libx11-6 libx11-data libx11-xcb1 libxapian30
libxcursor1 linux-image-4.9.0-8-amd64 linux-image-4.9.0-8-amd64-signed
mariadb-client-core-10.1 mariadb-common mariadb-server-core-10.1 okular
openssl perl perl-base perl-modules-5.24 php7.0 php7.0-cgi php7.0-cli
php7.0-common php7.0-json php7.0-ldap php7.0-mcrypt php7.0-opcache
php7.0-readline php7.0-xml policykit-1 python-samba
python-univention-appcenter python-univention-config-registry
python-univention-connector-s4 python-univention-directory-manager
python-univention-directory-manager-uvmm python-univention-lib
python-univention-virtual-machine-manager python2.7 python2.7-minimal
python3.5 python3.5-minimal qemu-kvm qemu-system-common qemu-system-x86
qemu-utils samba samba-common samba-common-bin samba-dsdb-modules samba-libs
samba-vfs-modules shell-univention-lib smbclient stunnel4 systemd
systemd-sysv tzdata udev univention-appcenter univention-appcenter-docker
univention-base-files univention-base-packages univention-config
univention-directory-listener univention-directory-manager-tools
univention-errata-level univention-join univention-ldap-acl-master
univention-ldap-client univention-ldap-config univention-ldap-server
univention-management-console univention-management-console-frontend
univention-management-console-web-server univention-policy-tools
univention-portal univention-quota univention-radius univention-s4-connector
univention-samba-local-config univention-samba4
univention-samba4-sysvol-sync univention-saml univention-saml-schema
univention-ssl univention-system-setup univention-updater
univention-virtual-machine-manager-schema univention-web-js
univention-web-style vlc-data vlc-plugin-base vlc-plugin-video-output
winbind xserver-common xserver-xorg-core
Maybe there is a process hanging (e.g. grub-probe). Please post the process list:
ps aux
Hey thank you for your reply.
the output from ps aux ist to long for a reply here:
https://pastebin.com/CMx4qKn9
I can’t see anything unusual. Do you have posted the full updater log? How works the connection to the internet? Is there a proxy involved?
I never did such a hughe jump on releases
I ever do step by step - 4.3-2 to 4.3-3 up to 4.3-5 then to 4.4-0 and up to 4.4-4
rg
Christian
No did not post the full updater log. I only postet the second attemt to upgarde the server.
There are some errors in it because the live server and domain controller has some restrictive DNS and MAC filtering/redirection going on.
I have moved the Server in test envieroment without the old Server and without DNS and MAC filtering. I did the backup to master transformation. and triggert the upgrade.
The Internet connection in my test envieroment is straightforward just a regular router (fritzbox). no proxy, no blocking firewall.
here is the full update log. i have marked the start of my first und second attemed to upgrade with a row of ===
https://pastebin.com/m7Xq564a
What’s “the old server”? Waht’s the role of the system you’re trying to upgrade?
ucr search --brief role
The old server is still dc master and is still active in another network but just in another network and will be shut down when the update is complete and everything works as it should. Then the new server will replace the old one.
I found a solution. After i started looking at all the files that have a modification date of today. I found a note in in var/log/univention-updater/univention-updater.status.details
media-change.. Please insert the disk labeled: UCS Linux 4.3....
i checked the /etc/apt/source.list there was only the UCS DVD as source.
Then copied some deb sources from etc/apt/sources.list.d/00_ucs-temporaystrusted intro the the /etc/apt/source.list
And resartet the upgearde in smaller steps with reboots in between to the latest version.
Ok that explains a lot. Maybe we should check your settings:
ucr search --brief repository
I dont understand why is only contained the dvd as reposetory:
local/repository:
online/repository/clean:
repository/app_center/blacklist:
repository/app_center/installed: DH-KD-KV-RA-S4-UV
repository/app_center/server: appcenter.software-univention.de
repository/app_center/whitelist:
repository/credentials/./password:
/uris:
repository/credentials/./username:
repository/credentials/Univention Software Repository/uris: updates.software-uni vention.de updates-test.software-univention.de appcenter.software-univention.de appcenter-test.software-univention.de
repository/mirror/architectures:
repository/mirror/basepath: /var/lib/univention-repository
repository/mirror/httpmethod:
repository/mirror/port:
repository/mirror/prefix:
repository/mirror/recreate_packages: no
repository/mirror/server:
repository/mirror/sources:
repository/mirror/threads: 10
repository/mirror/timeout:
repository/mirror/verify:
repository/mirror/version/end:
repository/mirror/version/start:
repository/mirror: no
repository/online/architectures:
repository/online/component/.
/clean:
repository/online/component/./description:
/localmirror:
repository/online/component/./password:
/port:
repository/online/component/./prefix:
/server:
repository/online/component/./unmaintained:
/username:
repository/online/component/./version:
repository/online/component/4.3-2-errata/description: Errata updates for UCS 4.3 -2
repository/online/component/4.3-2-errata/localmirror: true
repository/online/component/4.3-2-errata/version: 4.3
repository/online/component/4.3-2-errata: false
repository/online/component/4.3-3-errata/description: Errata updates for UCS 4.3 -3
repository/online/component/4.3-3-errata/localmirror: true
repository/online/component/4.3-3-errata/version: 4.3
repository/online/component/4.3-3-errata: false
repository/online/component/4.3-4-errata/description: Errata updates for UCS 4.3 -4
repository/online/component/4.3-4-errata/localmirror: true
repository/online/component/4.3-4-errata/version: 4.3
repository/online/component/4.3-4-errata: false
repository/online/component/4.3-5-errata/description: Errata updates for UCS 4.3 -5
repository/online/component/4.3-5-errata/version: 4.3
repository/online/component/4.3-5-errata: enabled
repository/online/component/4.4-0-errata/description: Errata updates for UCS 4.4 -0
repository/online/component/4.4-0-errata/localmirror: true
repository/online/component/4.4-0-errata/version: 4.4
repository/online/component/4.4-0-errata: false
repository/online/component/4.4-1-errata/description: Errata updates for UCS 4.4 -1
repository/online/component/4.4-1-errata/localmirror: true
repository/online/component/4.4-1-errata/version: 4.4
repository/online/component/4.4-1-errata: false
repository/online/component/4.4-2-errata/description: Errata updates for UCS 4.4 -2
repository/online/component/4.4-2-errata/localmirror: true
repository/online/component/4.4-2-errata/version: 4.4
repository/online/component/4.4-2-errata: false
repository/online/component/4.4-3-errata/description: Errata updates for UCS 4.4 -3
repository/online/component/4.4-3-errata/localmirror: true
repository/online/component/4.4-3-errata/version: 4.4
repository/online/component/4.4-3-errata: false
repository/online/component/4.4-4-errata/description: Errata updates for UCS 4.4 -4
repository/online/component/4.4-4-errata/version: 4.4
repository/online/component/4.4-4-errata: enabled
repository/online/httpmethod:
repository/online/port:
repository/online/prefix:
repository/online/server: https://updates.software-univention.de/
repository/online/sources:
repository/online/timeout:
repository/online/unmaintained: no
repository/online/verify:
repository/online: yes
rico@tjenerson:~$ sudo ucr search --brief repository
local/repository:
/uris:
repository/credentials/Univention Software Repository/uris: updates.software-univention.de updates-test.software-univention.de appcenter.software-univention.de appcenter-test.software-univention.de
/clean:
/localmirror:
/port:
/server:
/username:
repository/online/component/4.3-2-errata/description: Errata updates for UCS 4.3-2
repository/online/component/4.3-3-errata/description: Errata updates for UCS 4.3-3
repository/online/component/4.3-4-errata/description: Errata updates for UCS 4.3-4
repository/online/component/4.3-5-errata/description: Errata updates for UCS 4.3-5
repository/online/component/4.4-0-errata/description: Errata updates for UCS 4.4-0
repository/online/component/4.4-1-errata/description: Errata updates for UCS 4.4-1
repository/online/component/4.4-2-errata/description: Errata updates for UCS 4.4-2
repository/online/component/4.4-3-errata/description: Errata updates for UCS 4.4-3
repository/online/component/4.4-4-errata/description: Errata updates for UCS 4.4-4
Yes looks fine for me …
