While performing an upgrade from 4.1-4 to 4.2 the system stalled running joinscripts. This process took over 6 hours before reaching to that point.
There are several things left unconfigured. But when running dpkg --configure -a the system stall on the joinscripts without sending any information to the logs ( dpkg.log, updater.log).
Bellow some outputs:
root@mail:/etc/apt/sources.list.d# uname -a
Linux mail 4.1.0-ucs222-amd64 #1 SMP Debian 4.1.6-1.222.201701250821 (2017-01-25) x86_64 GNU/Linux
t@mail:/etc/apt/sources.list.d# cat 20_ucs-online-component.list
deb http://appcenter.software-univention.de/univention-repository/4.1/maintained/component/ oxseforucs_20170123162817/all/
deb http://appcenter.software-univention.de/univention-repository/4.1/maintained/component/ oxseforucs_20170123162817/amd64/
deb http://updates.software-univention.de/3.2/maintained/component/ 3.2-5-errata/all/
deb http://updates.software-univention.de/3.2/maintained/component/ 3.2-5-errata/amd64/
# Configuration error: component not found: oxoutlook783
# Configuration error: component not found: oxdrive783
deb http://appcenter.software-univention.de/univention-repository/4.1/maintained/component/ open-xchange-text_20160901105322/all/
deb http://appcenter.software-univention.de/univention-repository/4.1/maintained/component/ open-xchange-text_20160901105322/amd64/
deb http://updates.software-univention.de/4.1/maintained/component/ 4.1-4-errata/all/
deb http://updates.software-univention.de/4.1/maintained/component/ 4.1-4-errata/amd64/
# Configuration error: component not found: oxdrivehelp200
# Configuration error: component not found: oxmobility783
# Configuration error: component not found: oxofficeweb783
# Configuration error: component not found: oxoffice783
# Configuration error: component not found: oxreaderengine783
# Configuration error: component not found: oxusm783
# Configuration error: component not found: oxdocconv783
deb http://updates.software-univention.de/4.0/maintained/component/ 4.0-4-errata/all/
deb http://updates.software-univention.de/4.0/maintained/component/ 4.0-4-errata/amd64/
# Configuration error: component not found: backend783
deb http://updates.software-univention.de/3.2/maintained/component/ 3.2-7-errata/all/
deb http://updates.software-univention.de/3.2/maintained/component/ 3.2-7-errata/amd64/
# Configuration error: component not found: oxdocconvapi783
# Configuration error: component not found: frontend783
# Configuration error: component not found: frontend62213
root@mail:/etc/apt/sources.list.d# dpkg --audit
The following packages are only half configured, probably due to problems
configuring them the first time. The configuration should be retried using
dpkg --configure <package> or the configure menu option in dselect:
univention-portal Univention Portal - Central portal web page for a UCS dom
root@mail:/etc/apt/sources.list.d# dpkg --configure univention-portal
Setting up univention-portal (1.0.12-1A~4.2.0.201704022024) …
Calling joinscript 33univention-portal.inst …
2017-05-13 10:29:02.943991237-05:00 (in joinscript_init) < ---- IT STALLS HERE!!!
any help … higly appreciated.
Rolando Riley
