folgende Fehlermeldung bekomme ich.
19.02.14 10:41:29.711 DEBUG_INIT
**** Starting univention-updater with parameter=[’/usr/share/univention-updater/univention-updater’, ‘net’, ‘–updateto’, ‘3.2-1’, ‘–ignoressh’, ‘–ignoreterm’]
Version=3.2
Patchlevel=0
starting net mode
—>DBG:update_available(mode=net, cdrom_mount_point=/cdrom, iso=None)
Checking network repository
Update to = 3.2-1
**** Downloading scripts at Wed Feb 19 10:41:30 2014
**** Starting actual update at Wed Feb 19 10:41:31 2014
Running preup.sh script
Wed Feb 19 10:41:31 CET 2014
HINT:
Please check the release notes carefully BEFORE updating to UCS 3.2-1:
English version: docs.univention.de/release-notes-3.2-1-en.html
German version: docs.univention.de/release-notes-3.2-1-de.html
3rd party components.
Do you want to continue [Y/n]?
Custom preupdate script /var/lib/local-preup.sh not found
Checking for space on /var/cache/apt/archives: OK
Checking for space on /boot: OK
Checking for space on /: failed
ERROR: Not enough space in /, need at least 500 MB.
This may interrupt the update and result in an inconsistent system!
If neccessary you can skip this check by setting the value of the
config registry variable update32/checkfilesystems to “no”.
But be aware that this is not recommended!
Error: Update aborted by pre-update script of release 3.2-1
VMWare ESXi 5.0 U3
die VM hat 4 GB RAM 15 GB HDD
Was muss ich tun damit das Update klappt ?
Gruß Benny
