wir wollten von Zarafa umsteigen auf Open Xchange. Dabei haben wir die Zarafa module über das AppCenter deinstalliert und danach die Open Xchange module installiert. Dies wurde über die univention-management-console ohne fehler durchgeführt. Nach der Installation sollte univention-run-join-scripts ausgeführt werden. Dabei kam folgender fehler:
[code]root@ucs:~# univention-run-join-scripts
copyright © 2001-2016 Univention GmbH, Germany
Running 01univention-ldap-server-init.inst skipped (already executed)
Running 02univention-directory-notifier.inst skipped (already executed)
Running 03univention-directory-listener.inst skipped (already executed)
Running 04univention-ldap-client.inst skipped (already executed)
Running 05univention-bind.inst skipped (already executed)
Running 08univention-apache.inst skipped (already executed)
Running 10univention-ldap-server.inst skipped (already executed)
Running 11univention-heimdal-init.inst skipped (already executed)
Running 11univention-pam.inst skipped (already executed)
Running 12privacyidea.inst skipped (already executed)
Running 15univention-directory-notifier-post.inst skipped (already executed)
Running 15univention-heimdal-kdc.inst skipped (already executed)
Running 18python-univention-directory-manager.inst skipped (already executed)
Running 20univention-directory-policy.inst skipped (already executed)
Running 20univention-join.inst skipped (already executed)
Running 25univention-dhcp.inst skipped (already executed)
Running 26univention-nagios-common.inst skipped (already executed)
Running 28univention-icinga.inst skipped (already executed)
Running 28univention-nagios-server.inst skipped (already executed)
Running 30univention-appcenter.inst skipped (already executed)
Running 30univention-corporate-client-schema.inst skipped (already executed)
Running 30univention-nagios-client.inst skipped (already executed)
Running 31univention-nagios-ad-connector.inst skipped (already executed)
Running 31univention-nagios-libvirtd-kvm.inst skipped (already executed)
Running 31univention-nagios-s4-connector.inst skipped (already executed)
Running 31univention-nagios-uvmmd.inst skipped (already executed)
Running 34univention-management-console-server.inst skipped (already executed)
Running 34univention-self-service.inst skipped (already executed)
Running 35ucc-umc-images.inst skipped (already executed)
Running 35ucc-umc-setup.inst skipped (already executed)
Running 35univention-appcenter-docker.inst skipped (already executed)
Running 35univention-management-console-module-adconnector.skipped (already executed)
Running 35univention-management-console-module-adtakeover.iskipped (already executed)
Running 35univention-management-console-module-appcenter.inskipped (already executed)
Running 35univention-management-console-module-diagnostic.iskipped (already executed)
Running 35univention-management-console-module-ipchange.insskipped (already executed)
Running 35univention-management-console-module-join.inst skipped (already executed)
Running 35univention-management-console-module-klms.inst skipped (already executed)
Running 35univention-management-console-module-lib.inst skipped (already executed)
Running 35univention-management-console-module-mrtg.inst skipped (already executed)
Running 35univention-management-console-module-passwordchanskipped (already executed)
Running 35univention-management-console-module-pkgdb.inst skipped (already executed)
Running 35univention-management-console-module-printers.insskipped (already executed)
Running 35univention-management-console-module-quota.inst skipped (already executed)
Running 35univention-management-console-module-reboot.inst skipped (already executed)
Running 35univention-management-console-module-services.insskipped (already executed)
Running 35univention-management-console-module-setup.inst skipped (already executed)
Running 35univention-management-console-module-sysinfo.instskipped (already executed)
Running 35univention-management-console-module-top.inst skipped (already executed)
Running 35univention-management-console-module-ucr.inst skipped (already executed)
Running 35univention-management-console-module-udm.inst skipped (already executed)
Running 35univention-management-console-module-updater.instskipped (already executed)
Running 35univention-nagios-cups.inst skipped (already executed)
Running 35univention-nagios-dansguardian.inst skipped (already executed)
Running 35univention-nagios-squid.inst skipped (already executed)
Running 35univention-self-service-passwordreset-umc.inst skipped (already executed)
Running 36univention-management-console-module-apps.inst skipped (already executed)
Running 38univention-management-console-module-oxldb.inst skipped (already executed)
Running 40univention-postgresql.inst skipped (already executed)
Running 40univention-virtual-machine-manager-schema.inst skipped (already executed)
Running 43univention-virtual-machine-manager-node-common.inskipped (already executed)
Running 44univention-virtual-machine-manager-daemon.inst skipped (already executed)
Running 44univention-virtual-machine-manager-node-kvm.inst skipped (already executed)
Running 45univention-management-console-module-uvmm.inst skipped (already executed)
Running 50univention-pkgdb.inst skipped (already executed)
Running 51univention-ad-connector-exchange.inst skipped (already executed)
Running 62univention-bareos.inst skipped (already executed)
Running 65univention-ox.inst failed (exitcode: 1)
Running 67univention-mail-server.inst skipped (already executed)
Running 70iiiiiii4ucs-123.inst skipped (already executed)
Running 71iiiiiii4ucs-udm.inst skipped (already executed)
Running 78univention-kde.inst skipped (already executed)
Running 79univention-printserver.inst skipped (already executed)
Running 79univention-squid.inst skipped (already executed)
Running 80owncloud.inst skipped (already executed)
Running 80univention-radius.inst skipped (already executed)
Running 81univention-ad-connector.inst skipped (already executed)
Running 81univention-nfs-server.inst skipped (already executed)
Running 82univention-mail-dovecot.inst skipped (already executed)
Running 90univention-bind-post.inst skipped (already executed)
Running 91ucc-pxe-boot.inst skipped (already executed)
Running 91univention-saml.inst skipped (already executed)
Running 92plucs.inst skipped (already executed)
Running 92univention-management-console-web-server.inst skipped (already executed)
Running 94univention-openvpn-master.inst skipped (already executed)
Running 94univention-openvpn-server.inst skipped (already executed)
Running 94univention-openvpn-sitetosite.inst skipped (already executed)
Running 95ucc-2.1-thinclient-image.img.inst skipped (already executed)
Running 96univention-samba4.inst skipped (already executed)
Running 97univention-s4-connector.inst skipped (already executed)
Running 98univention-pkgdb-tools.inst skipped (already executed)
Running 98univention-samba4-dns.inst skipped (already executed)
[/code]
Wir hatten dann nach resten der Zarafa-Installation gesucht und diese dann mit apt-get purge zarafa* gelöscht. Dabei wurde darauf geachtet das nur Zarafa eigene Packete deinstalliert wurden. Da dies nicht half reinstallierten wir Opene Xchange erneut, jedoch blieb der fehler.
Die momentan installierte Version von UCS ist 4.1-1 errata116.
Alle Pakete sind aktuell.
MFG
Daniel Fischer
