banin
April 9, 2018, 8:27am
1
I had installed UCS 4.3 and after upload UCS license and rebooting server cant login and saw this error
Internal server error: The service is temporarily not available.
Cannot connect to the LDAP service.
The following steps can help to solve this problem:
Check if enough hard disk space and free RAM is available on this server or free some resources
Restart the LDAP service on the domain controller master either via “service slapd restart” on command line or with the UMC module “System services”
Hey,
sounds like your LDAP server isn’t running. Please log in via ssh & show the output of systemctl status slapd.service
Then try starting via systemctl start slapd.service and see if that makes a difference for the UMC.
Kind regards,
mosu
banin
April 9, 2018, 9:26am
3
Hi
I tried systemctl start slapd.service and nothing changed
Hey,
please post the output of the following commands:
univention-ldapsearch -s base dn
m.
banin
April 9, 2018, 10:13am
5
root@masterdc:~# systemctl start slapd.service
root@masterdc:~# systemctl status slapd.service
● slapd.service - LSB: OpenLDAP standalone server (Lightweight Directory Access
Loaded: loaded (/etc/init.d/slapd; generated; vendor preset: enabled)
Active: active (running) since Mon 2018-04-09 14:24:11 +0430; 17min ago
Process: 1523 ExecStart=/etc/init.d/slapd start (code=exited, status=0/SUCCESS
Main PID: 1972 (slapd)
Tasks: 4 (limit: 4915)
Memory: 17.3M
CPU: 233ms
CGroup: /system.slice/slapd.service
└─1972 /usr/sbin/slapd -h ldapi:/// ldap://:7389/ ldap://:389/ ldaps:
Apr 09 14:24:03 masterdc systemd[1]: Starting LSB: OpenLDAP standalone server (L
Apr 09 14:24:06 masterdc slapd[1954]: @(#) $OpenLDAP: slapd (Jan 9 2018 12:16:
Debian OpenLDAP Maintainers <pkg-o
Apr 09 14:24:07 masterdc slapd[1954]: Loaded metadata from "/usr/share/univentio
Apr 09 14:24:09 masterdc slapd[1523]: Starting ldap server(s): slapd ...done.
Apr 09 14:24:10 masterdc ldapsearch[1978]: DIGEST-MD5 common mech free
Apr 09 14:24:11 masterdc slapd[1523]: Checking Schema ID: ...done.
Apr 09 14:24:11 masterdc systemd[1]: Started LSB: OpenLDAP standalone server (Li
lines 1-20/20 (END)...skipping...
● slapd.service - LSB: OpenLDAP standalone server (Lightweight Directory Access Protocol)
Process: 1523 ExecStart=/etc/init.d/slapd start (code=exited, status=0/SUCCESS)
Memory: 17.3M
CPU: 233ms
└─1972 /usr/sbin/slapd -h ldapi:/// ldap://:7389/ ldap://:389/ ldaps://:7636/ ldaps://:63
Apr 09 14:24:03 masterdc systemd[1]: Starting LSB: OpenLDAP standalone server (Lightweight Directory
Apr 09 14:24:06 masterdc slapd[1954]: @(#) $OpenLDAP: slapd (Jan 9 2018 12:16:07) $
Debian OpenLDAP Maintainers <pkg-openldap-devel@lists.
Apr 09 14:24:07 masterdc slapd[1954]: Loaded metadata from "/usr/share/univention-management-console
Apr 09 14:24:11 masterdc systemd[1]: Started LSB: OpenLDAP standalone server (Lightweight Directory
root@masterdc:~# univention-ldapsearch -s base dn
ldap_start_tls: Can't contact LDAP server (-1)
