If a sleepy administrator wants to run missing join scripts, they might accidentally start univention-join
instead of univention-run-join-scripts
. While this is clearly a layer 8 problem, a bigger warning would not hurt. This happened to a friend, of course.
So instead of
univention-join: joins a computer to an ucs domain
it could say:
If you only want to run join scripts use univention-run-join-scripts!
