UCS update in webinterface not work
I have problem with Update module in UCS interface. After open Software -> Software update I see this screen:
ucs-update
But nothing happens…
Updating in console is working, UCS is now updated.
Starting univention-upgrade. Current UCS version is 4.4-2 errata291
Checking for local repository:                          none
Checking for package updates:                           none
Checking for app updates:                               none
Checking for release updates:                           none
root@ucs1:~#
If new update is available, I see notification in top right corner, but ater click on update, i get same screen " UCS is being updated…"
Server restart not help, still same problem…
How to fix Software update screen ?
Thanks
