Hi all.
When trying to install UCS (latest version from univention.de/download/ucs-download/ , no version information on iso filename, file commands reports 'UCS 4.0-3 amd64 1 ') on a small HP server we are facing several problems.
- Installation hangs at “setting up server role” (or similar).
- log file fills up with dbus error (missing /etc/machine-id).
- when rebooting at this step (after waiting for more than 10 hours…) installation seems to run fine but after reboot the management console is not available (no process listening on port 80/443).
- hardware errors are very unlikely.
Any hints?
Thanks in advance,
Christian
