Unfortunately does not work
Tue Oct 23 14:58:00 CEST 2018: starting /usr/sbin/univention-join -skipIpMac -dcname tux.gehr.lan
running version check
OK: UCS version on tux.gehr.lan is higher or equal (4.32) to the local version (4.32).
Stopping slapd (via systemctl): slapd.serviceWarning: slapd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
Starting slapd (via systemctl): slapd.serviceWarning: slapd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
Tue Oct 23 14:58:22 CEST 2018
Not registering IP and MAC, as requested with -skipIpMac
univention-server-join: joins a server to an univention domain
copyright (c) 2001-2018 Univention GmbH, Germany
ldap_dn="cn=kvm01,cn=dc,cn=computers,dc=gehr,dc=lan"
Setting hostname
Setting ldap/hostdn
File: /etc/stunnel/univention_saml.conf
File: /etc/libvirt/libvirtd.conf
Multifile: /etc/ldap/slapd.conf
File: /etc/welcome.msg
Multifile: /etc/simplesamlphp/metadata/saml20-idp-hosted.php
File: /etc/pam_ldap.conf
Multifile: /etc/postfix/ldap.virtualwithcanonical
File: /etc/issue
Multifile: /etc/postfix/ldap.external_aliases
Multifile: /etc/postfix/ldap.virtual_mailbox
Multifile: /etc/hosts
Multifile: /etc/postfix/ldap.groups
File: /etc/dhcp/dhclient.conf
Multifile: /etc/postfix/ldap.canonicalrecipient
Multifile: /etc/postfix/ldap.transport
File: /etc/libnss-ldap.conf
Multifile: /etc/postfix/ldap.canonicalsender
File: /etc/simplesamlphp/config.php
File: /etc/apache2/sites-available/univention-proxy.conf
Multifile: /etc/postfix/ldap.virtualdomains
Multifile: /etc/postfix/ldap.distlist
Multifile: /etc/postfix/ldap.sharedfolderlocal_aliases
File: /etc/apache2/conf-available/ucs.conf
File: /etc/mailname
File: /etc/cron.d/univention-directory-policy
File: /etc/pam.d/smtp
Multifile: /etc/postfix/main.cf
Multifile: /etc/simplesamlphp/authsources.php
Multifile: /etc/postfix/ldap.sharedfolderremote
File: /etc/hostname
Multifile: /etc/postfix/ldap.saslusermapping
Module: kopano-cfg
Multifile: /etc/apache2/sites-available/default-ssl.conf
Multifile: /etc/pam.d/univention-management-console
ok: down: univention-directory-notifier: 1441s
ok: down: univention-directory-listener: 0s
Setting ldap/server/name
Setting ldap/server/ip
Not updating ldap/server/port
Setting ldap/master
Not updating ldap/master/port
Setting ldap/server/type
File: /etc/krb5.conf
Module: kopano-cfg
File: /etc/init.d/slapd
File: /etc/default/ntpdate
File: /etc/nagios/nrpe.cfg
File: /etc/ntp.conf
File: /etc/ldap/ldap.conf
Clearing symlinks in /etc/ssl/certs...
done.
Updating certificates in /etc/ssl/certs...
152 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
Could not chdir to home directory /dev/null: Not a directory
Setting ssl/country
Setting ssl/state
Setting ssl/locality
Setting ssl/organization
Setting ssl/organizationalunit
Setting ssl/common
Setting ssl/email
Module: kopano-cfg
Restarting slapd (via systemctl): slapd.serviceWarning: slapd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
Not updating ldap/server/name
23.10.18 14:58:47.204 DEBUG_INIT
UNIVENTION_DEBUG_BEGIN : uldap.__open host=tux.gehr.lan port=7389 base=dc=gehr,dc=lan
UNIVENTION_DEBUG_END : uldap.__open host=tux.gehr.lan port=7389 base=dc=gehr,dc=lan
Setting kerberos/realm
Module: kopano-cfg
File: /etc/heimdal-kdc/kdc.conf
Setting windows/domain
Module: kopano-cfg
Setting dns/forwarder1
File: /etc/bind/named.conf.proxy
Module: kopano-cfg
File: /etc/bind/named.conf.samba4
Setting dns/forwarder2
Module: kopano-cfg
23.10.18 14:58:51.145 DEBUG_INIT
23.10.18 14:58:51.322 DEBUG_INIT
Configure 01univention-ldap-server-init.inst Tue Oct 23 14:58:51 CEST 2018
2018-10-23 14:58:51.374592614+02:00 (in joinscript_init)
WARNING!
Check file permissions!
Module: kopano-cfg
2018-10-23 14:58:56.138702431+02:00 (in joinscript_save_current_version)
Configure 02univention-directory-notifier.inst Tue Oct 23 14:58:56 CEST 2018
2018-10-23 14:58:56.187924101+02:00 (in joinscript_init)
Starting univention-directory-notifier (via systemctl): univention-directory-notifier.service.
2018-10-23 14:58:56.255403668+02:00 (in joinscript_save_current_version)
Configure 03univention-directory-listener.inst Tue Oct 23 14:58:56 CEST 2018
2018-10-23 14:58:56.305500998+02:00 (in joinscript_init)
23.10.18 14:58:56.853 DEBUG_INIT
23.10.18 14:58:57.772 LISTENER ( WARN ) : handler: replication (not ready) (ignore)
23.10.18 14:58:59.263 LISTENER ( WARN ) : handler: faillog (not ready) (ignore)
23.10.18 14:58:59.286 LISTENER ( WARN ) : Set Schema ID to 16
23.10.18 14:58:59.286 LISTENER ( WARN ) : initializing module replication
File: /var/lib/univention-ldap/ldap/DB_CONFIG
slapd: Kein Prozess gefunden
23.10.18 14:59:16.566 LISTENER ( WARN ) : finished initializing module replication with rv=0
23.10.18 14:59:16.566 LISTENER ( WARN ) : initializing module uvmmd-nodes
23.10.18 14:59:16.630 LISTENER ( WARN ) : finished initializing module uvmmd-nodes with rv=0
23.10.18 14:59:16.630 LISTENER ( WARN ) : initializing module portal
23.10.18 14:59:16.674 LISTENER ( PROCESS ) : Add / change obj
23.10.18 14:59:16.675 LISTENER ( PROCESS ) : Writing CSS file /usr/share/univention-portal/portal.css
23.10.18 14:59:16.676 LISTENER ( WARN ) : finished initializing module portal with rv=0
23.10.18 14:59:16.676 LISTENER ( WARN ) : initializing module keytab
23.10.18 14:59:16.708 LISTENER ( PROCESS ) : Exporting /etc/krb5.keytab on domaincontroller_backup
23.10.18 14:59:16.741 LISTENER ( PROCESS ) : Exporting /etc/krb5.keytab on domaincontroller_backup
23.10.18 14:59:16.775 LISTENER ( WARN ) : finished initializing module keytab with rv=0
23.10.18 14:59:16.775 LISTENER ( WARN ) : initializing module hosteddomains
23.10.18 14:59:16.824 LISTENER ( WARN ) : finished initializing module hosteddomains with rv=0
23.10.18 14:59:16.824 LISTENER ( WARN ) : initializing module umc-service-providers
23.10.18 14:59:17.508 LISTENER ( WARN ) : finished initializing module umc-service-providers with rv=0
23.10.18 14:59:17.508 LISTENER ( WARN ) : initializing module udm_extension
23.10.18 14:59:18.186 LISTENER ( WARN ) : finished initializing module udm_extension with rv=0
23.10.18 14:59:18.186 LISTENER ( WARN ) : initializing module ucc-nss-passwd
23.10.18 14:59:18.246 LISTENER ( WARN ) : finished initializing module ucc-nss-passwd with rv=0
23.10.18 14:59:18.246 LISTENER ( WARN ) : initializing module keytab-member
23.10.18 14:59:18.302 LISTENER ( WARN ) : finished initializing module keytab-member with rv=0
23.10.18 14:59:18.302 LISTENER ( WARN ) : initializing module license_uuid
23.10.18 14:59:18.536 LISTENER ( WARN ) : finished initializing module license_uuid with rv=0
23.10.18 14:59:18.536 LISTENER ( WARN ) : initializing module portal_entry
23.10.18 14:59:18.580 LISTENER ( PROCESS ) : Add or change: cn=wawision,cn=portal,cn=univention,dc=gehr,dc=lan
23.10.18 14:59:18.581 LISTENER ( PROCESS ) : Writing image to /usr/share/univention-portal/icons/entries/wawision.svg
23.10.18 14:59:18.585 LISTENER ( PROCESS ) : Add or change: cn=umc-local,cn=portal,cn=univention,dc=gehr,dc=lan
23.10.18 14:59:18.585 LISTENER ( PROCESS ) : Writing image to /usr/share/univention-portal/icons/entries/umc-local.svg
23.10.18 14:59:18.587 LISTENER ( PROCESS ) : Add or change: cn=umc-domain,cn=portal,cn=univention,dc=gehr,dc=lan
23.10.18 14:59:18.587 LISTENER ( PROCESS ) : Writing image to /usr/share/univention-portal/icons/entries/umc-domain.svg
23.10.18 14:59:18.589 LISTENER ( PROCESS ) : Add or change: cn=kopano-webapp,cn=portal,cn=univention,dc=gehr,dc=lan
23.10.18 14:59:18.589 LISTENER ( PROCESS ) : Writing image to /usr/share/univention-portal/icons/entries/kopano-webapp.svg
23.10.18 14:59:18.600 LISTENER ( PROCESS ) : Add or change: cn=univentionblog,cn=portal,cn=univention,dc=gehr,dc=lan
23.10.18 14:59:18.600 LISTENER ( PROCESS ) : Writing image to /usr/share/univention-portal/icons/entries/univentionblog.png
23.10.18 14:59:18.602 LISTENER ( PROCESS ) : Add or change: cn=server-overview,cn=portal,cn=univention,dc=gehr,dc=lan
23.10.18 14:59:18.602 LISTENER ( PROCESS ) : Writing image to /usr/share/univention-portal/icons/entries/server-overview.svg
23.10.18 14:59:18.613 LISTENER ( PROCESS ) : Add or change: cn=ucs-local-to-domain,cn=portal,cn=univention,dc=gehr,dc=lan
23.10.18 14:59:18.613 LISTENER ( PROCESS ) : Writing image to /usr/share/univention-portal/icons/entries/ucs-local-to-domain.svg
23.10.18 14:59:18.615 LISTENER ( WARN ) : finished initializing module portal_entry with rv=0
23.10.18 14:59:18.615 LISTENER ( WARN ) : initializing module nagios-client
23.10.18 14:59:18.683 LISTENER ( WARN ) : finished initializing module nagios-client with rv=0
23.10.18 14:59:18.683 LISTENER ( WARN ) : initializing module quota
UNIVENTION_DEBUG_BEGIN : uldap.__open host=kvm01.gehr.lan port=7389 base=dc=gehr,dc=lan
UNIVENTION_DEBUG_END : uldap.__open host=kvm01.gehr.lan port=7389 base=dc=gehr,dc=lan
23.10.18 14:59:18.971 LISTENER ( WARN ) : finished initializing module quota with rv=0
23.10.18 14:59:18.972 LISTENER ( WARN ) : initializing module ldap_server
23.10.18 14:59:19.991 LISTENER ( WARN ) : finished initializing module ldap_server with rv=0
23.10.18 14:59:19.991 LISTENER ( WARN ) : initializing module univention-saml-simplesamlphp-configuration
23.10.18 14:59:20.453 LISTENER ( WARN ) : finished initializing module univention-saml-simplesamlphp-configuration with rv=0
23.10.18 14:59:20.453 LISTENER ( WARN ) : initializing module bind
23.10.18 14:59:20.505 LISTENER ( WARN ) : finished initializing module bind with rv=0
23.10.18 14:59:20.505 LISTENER ( WARN ) : initializing module pkgdb-watch
23.10.18 14:59:20.544 LISTENER ( WARN ) : finished initializing module pkgdb-watch with rv=0
23.10.18 14:59:20.545 LISTENER ( WARN ) : initializing module nfs-shares
23.10.18 14:59:20.579 LISTENER ( WARN ) : finished initializing module nfs-shares with rv=0
23.10.18 14:59:20.579 LISTENER ( WARN ) : initializing module uvmmd-ldap
23.10.18 14:59:20.665 LISTENER ( WARN ) : finished initializing module uvmmd-ldap with rv=0
23.10.18 14:59:20.666 LISTENER ( WARN ) : initializing module portal_category
23.10.18 14:59:20.716 LISTENER ( PROCESS ) : Add or change: cn=admin,cn=categories,cn=portal,cn=univention,dc=gehr,dc=lan
23.10.18 14:59:20.719 LISTENER ( PROCESS ) : Add or change: cn=service,cn=categories,cn=portal,cn=univention,dc=gehr,dc=lan
23.10.18 14:59:20.730 LISTENER ( WARN ) : finished initializing module portal_category with rv=0
23.10.18 14:59:20.730 LISTENER ( WARN ) : initializing module faillog
23.10.18 14:59:20.780 LISTENER ( WARN ) : finished initializing module faillog with rv=0
23.10.18 14:59:20.780 LISTENER ( WARN ) : initializing module nscd_update
23.10.18 14:59:20.860 LISTENER ( WARN ) : finished initializing module nscd_update with rv=0
23.10.18 14:59:20.860 LISTENER ( WARN ) : initializing module ldap_extension
Aktualisieren der Domäne "9f2cb61d-0e38-49e2-af27-3b3c8797bc25" fehlgeschlagen
Aktualisieren der Domäne "e734301c-a565-4c11-ada0-b66342643e5d" fehlgeschlagen
Aktualisieren der Domäne "a67d40ba-02a3-42b2-a960-6b7e359a6028" fehlgeschlagen
Aktualisieren der Domäne "8e187e06-9491-4e9e-b311-a4e21ed627fe" fehlgeschlagen
Aktualisieren der Domäne "f9c99d25-27d0-4d6e-b018-7bcf3e2e5c6b" fehlgeschlagen
Aktualisieren der Domäne "51c568a1-dee1-434c-821b-302eabd9ebe1" fehlgeschlagen
Aktualisieren der Domäne "13a757bd-e41a-427a-96d8-994088695b70" fehlgeschlagen
Aktualisieren der Domäne "e0e884ce-e704-44d7-93da-1e02ea436fb6" fehlgeschlagen
Aktualisieren der Domäne "e428f050-56db-4850-8b8b-df6e624ac127" fehlgeschlagen
Aktualisieren der Domäne "c3f7486e-229e-4cc2-b544-f98753c23cca" fehlgeschlagen
Aktualisieren der Domäne "4b1b9220-b7d3-464e-81a7-7454820a5ba3" fehlgeschlagen
Aktualisieren der Domäne "a638fca0-0e6d-42f1-9d93-17c307ee7b83" fehlgeschlagen
Aktualisieren der Domäne "2276820c-ae95-4dfd-9ff6-203b459884c9" fehlgeschlagen
Aktualisieren der Domäne "2191b99f-ab6c-4b99-a68f-bd9baeb54cb5" fehlgeschlagen
Aktualisieren der Domäne "a589bf8a-0b0b-4255-982d-4ce7efb3367b" fehlgeschlagen
23.10.18 14:59:23.995 LISTENER ( PROCESS ) : ldap_extension: ignore first appearance of cn=66univention-appcenter_app,cn=ldapacl,cn=univention,dc=gehr,dc=lan, not yet activated
23.10.18 14:59:24.747 LISTENER ( WARN ) : finished initializing module ldap_extension with rv=0
23.10.18 14:59:24.747 LISTENER ( WARN ) : initializing module univention-saml-idp-config
23.10.18 14:59:24.964 LISTENER ( WARN ) : finished initializing module univention-saml-idp-config with rv=0
23.10.18 14:59:24.964 LISTENER ( WARN ) : initializing module gencertificate
23.10.18 14:59:25.002 LISTENER ( WARN ) : finished initializing module gencertificate with rv=0
23.10.18 14:59:25.002 LISTENER ( WARN ) : initializing module nfs-homes
23.10.18 14:59:25.040 LISTENER ( WARN ) : finished initializing module nfs-homes with rv=0
23.10.18 14:59:25.040 LISTENER ( WARN ) : initializing module nss
23.10.18 14:59:25.123 LISTENER ( WARN ) : finished initializing module nss with rv=0
23.10.18 14:59:25.123 LISTENER ( WARN ) : initializing module well-known-sid-name-mapping
23.10.18 14:59:25.227 LISTENER ( PROCESS ) : well-known-sid-name-mapping: ucr set groups/default/printoperators=Printer-Admins
23.10.18 14:59:27.110 LISTENER ( WARN ) : finished initializing module well-known-sid-name-mapping with rv=0
23.10.18 14:59:27.110 LISTENER ( WARN ) : initializing module univention-saml-servers
23.10.18 14:59:27.515 LISTENER ( WARN ) : finished initializing module univention-saml-servers with rv=0
23.10.18 14:59:27.515 LISTENER ( WARN ) : initializing module libvirtd-acl
23.10.18 14:59:27.610 LISTENER ( WARN ) : finished initializing module libvirtd-acl with rv=0
70093
Restarting nagios-nrpe-server (via systemctl): nagios-nrpe-server.service.
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70204="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70205="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70206="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70207="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70208="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70209="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70210="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70211="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70212="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70213="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70214="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70215="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70216="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70217="" exited with 1
23.10.18 14:59:28.289 LISTENER ( WARN ) : DNS: 70218="" exited with 1
zone refresh queued
zone refresh queued
23.10.18 14:59:43.306 LISTENER ( WARN ) : DNS: Pending children: 70474 70476
rndc: recv failed: operation canceled
23.10.18 14:59:44.308 LISTENER ( WARN ) : DNS: 70474="rndc -p 55555 reload gehr.lan" exited with 1
23.10.18 14:59:44.308 LISTENER ( WARN ) : DNS: 70476="rndc -p 55555 reload 24.168.192.in-addr.arpa" exited with 1
Setting umc/saml/trusted/sp/tux.gehr.lan
File: /etc/ldap/sasl2/slapd.conf
Module: kopano-cfg
Setting umc/saml/trusted/sp/pluto.gehr.lan
Module: kopano-cfg
Setting umc/saml/trusted/sp/saturn.gehr.lan
Module: kopano-cfg
Setting umc/saml/trusted/sp/ucstest01.gehr.lan
Module: kopano-cfg
Setting license/base
Setting uuid/license
Module: univention_blog
Module: kopano-cfg
File: /usr/share/univention-management-console/meta.json
File: /etc/apt/apt.conf.d/55user_agent
Setting ldap/master
Setting kerberos/adminserver
Module: kopano-cfg
File: /etc/ntp.conf
Setting saml/idp/ldap/get_attributes
Module: kopano-cfg
Setting groups/default/printoperators
File: /etc/security/access-sudo.conf
File: /etc/security/access-ftp.conf
File: /etc/security/access-kscreensaver.conf
File: /etc/security/access-passwd.conf
File: /etc/security/access-su.conf
File: /etc/security/access-chfn.conf
File: /etc/security/access-cron.conf
File: /etc/security/access-kdm.conf
File: /etc/security/access-rsh.conf
File: /etc/security/access-chsh.conf
File: /etc/security/access-kcheckpass.conf
File: /etc/security/access-kde.conf
File: /etc/security/access-ppp.conf
File: /etc/security/access-rlogin.conf
File: /etc/security/access-screen.conf
File: /etc/security/access-login.conf
File: /etc/security/access-gdm.conf
File: /etc/security/access-sshd.conf
File: /etc/security/access-other.conf
File: /etc/security/limits.conf
Module: kopano-cfg
Setting ucs/server/saml-idp-server/tux.gehr.lan
Module: kopano-cfg
Restarting univention-directory-listener (via systemctl): univention-directory-listener.service.
2018-10-23 14:59:45.364322596+02:00 (in joinscript_save_current_version)
Configure 04univention-ldap-client.inst Tue Oct 23 14:59:46 CEST 2018
2018-10-23 14:59:46.165504869+02:00 (in joinscript_init)
Setting nsswitch/ldap
Module: kopano-cfg
File: /etc/nsswitch.conf
2018-10-23 14:59:46.570632827+02:00 (in joinscript_save_current_version)
Configure 05univention-bind.inst Tue Oct 23 14:59:46 CEST 2018
2018-10-23 14:59:46.616442302+02:00 (in joinscript_init)
wait for named ?
Failed creating the DNS zone gehr.lan.\nCommand failed with 1:\nE: failed super(type, obj): obj must be an instance or subtype of type
Adding ZONE record "root@gehr.lan. 1 28800 7200 604800 10800 kvm01.gehr.lan." to zone gehr.lan...
File "/usr/share/univention-admin-tools/univention-dnsedit", line 460, in <module>
main()
File "/usr/share/univention-admin-tools/univention-dnsedit", line 433, in main
add_zone(*args)
File "/usr/share/univention-admin-tools/univention-dnsedit", line 387, in add_zone
zone['refresh'] = [refresh]
File "/usr/lib/pymodules/python2.7/univention/admin/handlers/__init__.py", line 433, in __setitem__
p = s.parse(value)
File "/usr/lib/pymodules/python2.7/univention/admin/syntax.py", line 1616, in parse
return super(UNIX_TimeInterval, cls).parse(texts)
TypeError: super(type, obj): obj must be an instance or subtype of type
__JOINERR__:FAILED: /usr/lib/univention-install/05univention-bind.inst
Configure 08univention-apache.inst Tue Oct 23 14:59:48 CEST 2018
2018-10-23 14:59:48.050490131+02:00 (in joinscript_init)
Module ssl disabled.
To activate the new configuration, you need to run:
systemctl restart apache2
Considering dependency setenvif for ssl:
Module setenvif already enabled
Considering dependency mime for ssl:
Module mime already enabled
Considering dependency socache_shmcb for ssl:
Module socache_shmcb already enabled
Enabling module ssl.
See /usr/share/doc/apache2/README.Debian.gz on how to configure SSL and create self-signed certificates.
Site default-ssl disabled.
systemctl reload apache2
Enabling site default-ssl.
Reloading apache2 configuration (via systemctl): apache2.service.
2018-10-23 14:59:48.671985262+02:00 (in joinscript_save_current_version)
Configure 10univention-ldap-server.inst Tue Oct 23 14:59:48 CEST 2018
2018-10-23 14:59:48.712862754+02:00 (in joinscript_init)
WARNING!
Module: kopano-cfg
SRV record _ldap._tcp for port 7389 not created because Samba4 DCs are present: tux
wait for named ?
Does not exist
wait for named ?
Adding ZONE record "root@gehr.lan. 1 28800 10800 604800 108001 kvm01.gehr.lan." to zone 192.168.24...
main()
add_zone(*args)
p = s.parse(value)
__JOINERR__:FAILED: /usr/lib/univention-install/10univention-ldap-server.inst
* Join failed! *
* Contact your system administrator *
* Message: Please visit https://help.univention.com/t/8842 for common problems during the join and how to fix them -- FAILED: 10univention-ldap-server.inst
Tue Oct 23 15:00:05 CEST 2018: finish /usr/sbin/univention-join
