I have the following challenge, installation of nextcloud fails due various missing packages and version mismatches
Installed UCS Version
root@dc1:/tmp# lsb_release -a
No LSB modules are available.
Distributor ID: Univention
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
root@dc1:/tmp# tail -n 5 /var/log/univention/updater.log
Starting univention-upgrade. Current UCS version is 5.0-3 errata572
Checking for package updates: none
Checking for app updates: none
Checking for release updates: none
Nextcloud Installation
but why 4.4 License Agreement ???
univention-app install nextcloud
Resolving dependencies for nextcloud
Going to install Nextcloud Hub (24.0.7-1)
Password for Administrator:
Showing License agreement for 4.4/nextcloud=24.0.7-1
Postgresql Package not found - because only the newer one postgresql-11 available through univention repository
E: Unable to locate package univention-postgresql
Could not install software packages
Aborting...
Going to remove Nextcloud Hub (24.0.7-1)
Showing README for 4.4/nextcloud=24.0.7-1
Uninstalling Nextcloud keeps your data.
Manual installing :
cat /usr/share/univention-errata-level/maintained-packages.txt | grep postgresql
postgresql-server-dev-11
postgresql-server-dev-all
univention-postgresql-11
univention-app install univention-postgresql
univention-app install: error: Unable to find app univention-postgresql. Maybe “/usr/bin/univention-app update” to get the latest list of applications?
→ univention-postgresql are available on maintained package list
any ideas ?
