UCS 4.3 and Owncloud 10.8 Integrity fail
I need help solving this issue. I am getting a integrity check fail missing files.
the missing files are
  • /updater/vender/autoload.php
  • /updater/vender/autoload_static.php
    -/updater/vender/autoload_real.php
I tried to use winscp and a download of owncloud 10.4 to copy the files over but not sure where to copy the files to what directory since there is a ton of directory’s. In ownlcoud it a under /Var/www/owncloud/updates/vender/ but in the winscp program to transfer i see everything and not sure where UCS store them and what I need to do to fix this issue.
Thank you
Brock
