Ucr commit fails with python error
Hi there, I got several problems on UCS 5.0-9 errata1228 because ucr commit does not work any more. I get a lot of python errors, none of them of any help for me. I’m not aware of any recent changes that could have triggered the problem.
The complete output of ucr commit is shown below, pease help! Thanks!
  File "/usr/lib/python3/dist-packages/univention/config_registry/handler.py", line 708, in load
    version = self._get_cache_version(cache_file)
  File "/usr/lib/python3/dist-packages/univention/config_registry/handler.py", line 682, in _get_cache_version
    match = ConfigHandlers.VERSION_RE.match(line)
TypeError: cannot use a string pattern on a bytes-like object
During handling of the above exception, another exception occurred:
  File "/usr/sbin/ucr", line 72, in <module>
    sys.exit(ub.main(convertToUtf8(sys.argv[1:])))
  File "/usr/lib/python3/dist-packages/univention/config_registry/frontend.py", line 865, in main
    result = handler_func(args, cmd_opts)
  File "/usr/lib/python3/dist-packages/univention/config_registry/frontend.py", line 340, in handler_commit
    handlers.load()
  File "/usr/lib/python3/dist-packages/univention/config_registry/handler.py", line 723, in load
    self.update()
  File "/usr/lib/python3/dist-packages/univention/config_registry/handler.py", line 926, in update
    handler = self.get_handler(section)
  File "/usr/lib/python3/dist-packages/univention/config_registry/handler.py", line 739, in get_handler
    return handler(entry)
  File "/usr/lib/python3/dist-packages/univention/config_registry/handler.py", line 807, in _get_handler_file
    handler.variables = grep_variables(fd.read())
  File "/usr/lib/python3.7/codecs.py", line 322, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xfc in position 958: invalid start byte
Sorry, solved it myself. I had made some changes to /etc/univention/templates/files/etc/apache2/sites-available/univention.conf that were obviously not accepted by the system. Some mod_rewrite stuff. Thought those changes were supposed to go in there. Now it works anyhow-
