I want to transfer one folder from user “User1” to “User2” but gives allways error.
- Two users created on ownCloud: “User1” and “User2”
- One folder shared with other users from account of user “User1” (owner of the folder shared)
- Run command: occ files:transfer-ownership --path="/Shared Folder1" User1 User2
- Gives always the error:
“In Share.php line 173:
[OCP\Files\NotFoundException]”
Operating system :
Current UCS version is 4.4-4 errata652
ownCloud version:
10.3.2-1
Error with verbose activated:
root@xxxxxxx: /var/www/owncloud # occ -vvv files:transfer-ownership --path="/Shared Folder1" User1 User2
Analysing files of User1 …
95 [============================] 1 sec 20.0 MiB
Collecting all share information for files and folder of User1 …
2 [–>-------------------------] 1 sec 22.0 MiB
Exception trace:
at /var/www/owncloud/lib/private/Share20/Share.php:173
OC\Share20\Share->getNode() at /var/www/owncloud/apps/files/lib/Command/TransferOwnership.php:267
OCA\Files\Command\TransferOwnership->OCA\Files\Command{closure}() at n/a:n/a
array_filter() at /var/www/owncloud/apps/files/lib/Command/TransferOwnership.php:269
OCA\Files\Command\TransferOwnership->collectUsersShares() at /var/www/owncloud/apps/files/lib/Command/TransferOwnership.php:165
OCA\Files\Command\TransferOwnership->execute() at /var/www/owncloud/lib/composer/symfony/console/Command/Command.php:255
Symfony\Component\Console\Command\Command->run() at /var/www/owncloud/lib/composer/symfony/console/Application.php:982
Symfony\Component\Console\Application->doRunCommand() at /var/www/owncloud/lib/composer/symfony/console/Application.php:255
Symfony\Component\Console\Application->doRun() at /var/www/owncloud/lib/composer/symfony/console/Application.php:148
Symfony\Component\Console\Application->run() at /var/www/owncloud/lib/private/Console/Application.php:165
OC\Console\Application->run() at /var/www/owncloud/console.php:106
require_once() at /var/www/owncloud/occ:11
files:transfer-ownership [–path PATH] [–]
